problem with power antenna
Old Dec 10, 2007 | 09:56 AM
teg_dc2's Avatar
Default problem with power antenna
i got a problem wit my antenna seems like it wont go down, it makes noise so the motor isnt burned out should i replace the antenna or what??
Old Dec 10, 2007 | 10:07 AM
wastedyouth2542's Avatar
Default Re: problem with power antenna (teg_dc2)
there is a band that connects the two gears togeather to raise or lower the antenna you have to tear the motor apart and but the band back on, thats what happened to mine, i think my system knocked it off..
Old Dec 10, 2007 | 10:57 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">i got a problem wit my antenna seems like it wont go down, it makes noise so the motor isnt burned out should i replace the antenna or what?? </TD></TR></TABLE>
That's how mine was when I bought the car. There is a white band with teeth on it that is probably broken that raises and lowers your mast. I have seen replacement kits for about $10 but have never used them, since I managed to break the antenna motor when I went to take it apart. (oops) I got an OEM factory unit off ebay for about $20 - no problems since then.
Some ppl replace the antenna with the Honda S2000 unit, but I've heard the reception is less than stellar when installed in our tegs.
Good luck.
Old Dec 10, 2007 | 11:01 AM
TonyRomo's Avatar
Default Re: problem with power antenna (Tim2179)
sometimes when my car has been sitting there not running for like 3 hours it will randomly make weird *** noises that I think are coming from the antenna motor, no idea why.
figured I would add that
Old Dec 10, 2007 | 11:39 AM
agrn93ls's Avatar
what you need is called an antenna "mast" its the actual "airial" (sp) the mast is the part that goes up and down it has a plastic gear that runs the length of the "airial" they break over time. i would highly suggest you get one from the dealer and carefully read over the directions on how to replace, if you have never done it it can be a pain in the ***. but once you know how its very easy.
Don Drift
Sep 15, 2015 02:33 PM
paniaguae640
Sep 5, 2007 10:16 AM
Sarren
Jun 26, 2005 01:58 PM
R81_DC2
May 4, 2005 11:31 AM
