Need some help with Engine stuff!
Old Dec 10, 2007 | 02:00 PM
jordan_civic's Avatar
Default Need some help with Engine stuff!
Ok...when It comes to engine building im a little noob for some things and just need to ask someone some questions who knows what they are talkin about.
So If you can just reply to this or IM Id greatly appreciate the help
Old Dec 10, 2007 | 02:41 PM
Jackson123's Avatar
Default Re: Need some help with Engine stuff! (jordan_civic)
I know a little of this, and a little of that, whats going down?
Old Dec 10, 2007 | 02:43 PM
imsickofrice's Avatar
Default Re: Need some help with Engine stuff! (Jackson123)
it would help if you posted what you need help with specifically.. question is too broad.
Old Dec 10, 2007 | 02:46 PM
Default Re: Need some help with Engine stuff! (imsickofrice)
Yeah I have a ton of random questions...
one i guess is after your done building the engine and you swap it back in how do you get all the other things set to work. Like oil pump, water pump, .....I have more questions just gotta think
brb gotta eat
Old Dec 10, 2007 | 02:52 PM
potmilkz's Avatar
i got a question.
during a jdm gsr swap.... into a 98 ls integra do i have to add in some extra sensor wires on the engine harness?
Old Dec 10, 2007 | 03:06 PM
Default Re: (potmilkz)
I guess to sum up all my questions... I know how to assemble the block, heard, etc. but I do not know what to do otherwise. Like between when all is still assembled on the car getting ready disconnect everything and when its all disconnected ready to be lifted out. And then when you re assemble everything and is in the engine bay read to start attaching everything....
If you can understand what I mean...
Old Dec 10, 2007 | 03:32 PM
all-mtr-teg's Avatar
Default Re: (jordan_civic)
Well if you were the one who removed the engine, as in disconnecting all the hose, belts, sensors, power steering, air compressors, alternator, intake manifold, exhaust this should be easy. Then build the mortor and then install the motor and tranny, get them mounted in place and then reinstall everything you removed.
Old Dec 10, 2007 | 03:36 PM
PrinceAli132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by potmilkz &raquo;</TD></TR><TR><TD CLASS="quote">i got a question.
during a jdm gsr swap.... into a 98 ls integra do i have to add in some extra sensor wires on the engine harness?</TD></TR></TABLE>
Add wiring for vtec solenoid, pressure switch, IAB, and knock sensor if your using it. Check out the hybrid section.
Jordan_Civic,
Get a Helms manual.
http://www.helminc.com/helm/se...1C8U4
Ali
02Accorder
Mar 3, 2014 10:34 AM
zZWHITEDUDEZz
Feb 20, 2014 12:45 PM
Kansas
Nov 15, 2013 04:00 PM
eg2jr
Southern California
Dec 29, 2011 10:03 PM
Phoenix1
Mar 4, 2003 05:00 PM
