DA integra fuel problem. Code 43
Old Dec 11, 2007 | 04:58 AM
thatnikkashoD's Avatar
Default DA integra fuel problem. Code 43
So i just checked my ECU and it was throwing Code 43. Fuel Supply System.
My car dies out on me like its not being fed gas at certain times. Any one know what i can do to overcome this nightmare ive been having with this problem?
Old Dec 11, 2007 | 05:22 AM
Default Re: DA integra fuel problem. Code 43 (thatnikkashoD)
Old Dec 11, 2007 | 05:24 AM
GRAF-FITI's Avatar
* B A N N E D *
you can start cheap by having your injectors flushed and changing your fuel filter
Old Dec 11, 2007 | 12:15 PM
JDMITRTURBO's Avatar
Default Re: DA integra fuel problem. Code 43 (GRAF-FITI)
I am also haven a fuel problem...I think anyways...Car just wont start, but trys and all I can think of is the fuel pump...You have a DA, so I didn't know if you would have a idea of how I would know if I have a bad fuel pump or not...
New Fuel pump is like $130 and I have to drop the tank so I dont just want to go fixing something that might not be broke...
Anyhelp would be great, or even what you think...
Old Dec 11, 2007 | 04:36 PM
Lord Helmet's Avatar
Default Re: DA integra fuel problem. Code 43 (JDMITRTURBO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMITRTURBO &raquo;</TD></TR><TR><TD CLASS="quote">I am also haven a fuel problem...I think anyways...Car just wont start, but trys and all I can think of is the fuel pump...You have a DA, so I didn't know if you would have a idea of how I would know if I have a bad fuel pump or not...
Anyhelp would be great, or even what you think... </TD></TR></TABLE>
if you have a honda/acura you don't need to drop the tank to get to the fuel pump. just remove the rear bottom seat cushion.
Old Dec 11, 2007 | 05:05 PM
92gisser's Avatar
Default Re: DA integra fuel problem. Code 43 (Lord Helmet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet &raquo;</TD></TR><TR><TD CLASS="quote">
if you have a honda/acura you don't need to drop the tank to get to the fuel pump. just remove the rear bottom seat cushion.</TD></TR></TABLE>
I believe with OBD0 Integras you do have to drop the tank to get to the fuel pump.
Old Dec 12, 2007 | 11:46 AM
Default Re: DA integra fuel problem. Code 43 (92gisser)
I replaced the fuel injectors. Everthing runs perfectly fine now. Also its faster :D
Old Feb 23, 2008 | 03:26 PM
jcedwards84's Avatar
Did your car Idle rough before you changed the injectors? Wonder why it didn't shoot you code 16 if it was the injectors...
Old Feb 23, 2008 | 08:15 PM
truejdm2's Avatar
Default Re: DA integra fuel problem. Code 43 (jcedwards84)
i used to have same problem here .... i just change the o2 sensor everything is running great now...
Old Feb 23, 2008 | 08:54 PM
Default Re: DA integra fuel problem. Code 43 (truejdm2)
Hmmm, I have replaced my fuel filter, o2 sensor, and 2 different used regulators (cousin works at a honda junkyard so I get them for free :D). Im still jumping between 300 and 1500 RPM randomly, it will be like 800rpm for 30 sec, then 500rpm for 3sec, then 1200rpm.... and it spits out code 43 when I sit and let it warm up. BTW, I drive a 90 hatch with B18 swap, and matching integra ECU.
rbizzell30
May 9, 2009 04:27 AM
wheelmaneg6
Oct 31, 2006 03:45 PM
cincispeedemon
Nov 22, 2004 05:51 PM
