Noob question.
Old Dec 5, 2007 | 08:57 PM
steveteggy92's Avatar
Default Noob question.
So, i want to check the level of my transmission fluid, the motor is a b18a in a 92 GS 5 spd. Looked at my hondahookup manual and found the level, and drain plugs, but where the heck are they on the actual car lol?
Thanks in advance.
-Steve
Old Dec 5, 2007 | 09:03 PM
posHonda's Avatar
There is nothing like a dipstick or anything that allows you to check the fluid level like you would do motor oil. Drain it and there should be ~3.2qts in there.
Old Dec 5, 2007 | 09:13 PM
ls19integra95's Avatar
Default Re: (posHonda)
do not drain it just to check the level... the drain plug is a 3/8 ratchet to remove and the check/fill plug is a 17mm plug... the check is on the very side toward the middle of the trans closest to your passenger tire... the drain plug is on the side also near the bottom of your trans... the trans fluid should be right at the check plug... you should be able to stick your finger in to about your first joint and get fluid on your finger, if not then its low... otherwise if you do get the fluid on your finger then your fine...
Old Dec 5, 2007 | 11:22 PM
guygeneric's Avatar
Default Re: (ls19integra95)
bump to that! i guess i learn something new everyday, i've been wondering how to check that for awhile.
Old Dec 6, 2007 | 04:07 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Noob question. (steveteggy92)
Fill/check: bolt 18
Drain: bolt 12
Old Dec 18, 2007 | 06:42 PM
BillyBoom29's Avatar
I'm a noob and whenever I have a question or problem with something, I do find post to be helpful.
As a noob, I'm not trying to be stupid and that illiterate. I also don't want to be categorized as an internet thug. I just like to keep things simple.
Old Dec 18, 2007 | 07:37 PM
PACT man's Avatar
Default Re: (BillyBoom29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by posHonda &raquo;</TD></TR><TR><TD CLASS="quote">There is nothing like a dipstick or anything that allows you to check the fluid level like you would do motor oil. Drain it and there should be ~3.2qts in there.</TD></TR></TABLE>
You got that backwards, there should be about 2.3 qts in the manual tranny.
Moosa S
Honda Civic (2006 - 2015)
Nov 13, 2018 03:19 PM
niceprelude
10
Feb 8, 2009 04:20 PM
niceprelude
11
Feb 4, 2009 02:10 PM
matryx
Jul 17, 2007 04:44 PM
Y2KGreenGSR
Sep 28, 2001 12:11 PM
