cel code 90 or 9 help.
Old Dec 6, 2007 | 09:27 PM
Maui Built's Avatar
Default cel code 90 or 9 help.
i have a 99 gsr and im either throwing a 9 or 90. Im pretty sure its not a code 9 because my car is running perfectly fine and not im limp mode so im guessing its most likely 90 which is Evaporative Emission Control System Leak Detected. i just changed my gas cap and the light went away for about 45 miles of driving and it just came on again. im thinking about changing the vacum hoses for the charcoal canister but besides that what else can i look for? and how serious is this problem? could it cause any major damage in the future? TIA.
Old Dec 7, 2007 | 12:02 AM
type-GGSR's Avatar
Default Re: cel code 90 or 9 help. (Maui Built)
yay finally someone with the same problem. I have a code 90 on my 98 GSR as well.
Old Dec 7, 2007 | 08:26 AM
Maui Built's Avatar
Default Re: cel code 90 or 9 help. (type-GGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-GGSR &raquo;</TD></TR><TR><TD CLASS="quote">yay finally someone with the same problem. I have a code 90 on my 98 GSR as well.</TD></TR></TABLE>
how long have you been running with this code? you notice any other problems? it also seems like the light only comes back on when i get below half tank? bump!
Old Dec 7, 2007 | 12:29 PM
type-GGSR's Avatar
probably 2 weeks now. Ill try and change the gas cap. see if that works. Also im gonna reset the ECU and see if it does come back when the tank is at half.
Old Dec 8, 2007 | 07:23 AM
Maui Built's Avatar
type-G, if that doesnt work try changing all of the vacum hoses connecting to the vapor canister and try cleaning out the vapor purge valve on the top of the canister with some qd electrical contact cleaner. im going to try this today hoefully it works
Old Dec 9, 2007 | 10:50 PM
Maui Built's Avatar
i changed both vacum hoses 1. from the canister to the steel ahrds line 2. from the canister to the valve on the IM, and also cleaned out the canister purge valve. and still no go. im going to try to test the purge valve next and if its not a bad purge valve i need to check the fuel tank area =\
Old Jan 24, 2008 | 11:22 PM
THEGUYFROMSOCAL's Avatar
Banned
Default Re: (Maui Built)
I have this same problem. I am going to have to spend a day to fix it, but I was trying to see if anyone has a staright fix or solution. Ill post if I get it figured out.
Old Jan 24, 2008 | 11:34 PM
Maui Built's Avatar
check your gas cap, hoses, valve on the canister, and valve on the intake manifold. let me know if you find the problem!
Old Jan 27, 2008 | 09:05 AM
importknight's Avatar
same problem on my 98 ITR just happened yesterday, do u guys got pics to help me out in the location of the canister etc.
one of us will find the cure fro the problem lol
Old Jan 27, 2008 | 09:39 AM
Maui Built's Avatar
Default Re: (importknight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importknight &raquo;</TD></TR><TR><TD CLASS="quote">same problem on my 98 ITR just happened yesterday, do u guys got pics to help me out in the location of the canister etc.
one of us will find the cure fro the problem lol</TD></TR></TABLE>
canister is right below the battery. it has hoses coming out the top of it you cant miss it.
Old Jan 27, 2008 | 09:40 AM
thx but, did u find out what the problem is on urs yet?
Old Jan 27, 2008 | 09:58 PM
Maui Built's Avatar
it hasnt came back on for a while b/c i unplugged my battery. i put it on a obd2 tester instead of just jumping the ecu w/ a paperclip and the tester told me to replace the fuel cap..which i already did..so idk what else to do?
Old Jan 31, 2008 | 05:02 PM
type-GGSR's Avatar
I just replaced my gas cap , reset the ecu and the CEL hasnt come on. Hopefully it solved the problem
Old Jan 31, 2008 | 09:49 PM
Maui Built's Avatar
wait for about 80-100 miles if it doesnt come back on good job!
Old Feb 5, 2008 | 12:40 AM
type-GGSR's Avatar
damnnnit. right when my fuel tank hit half, it came back on! checked the ecu to see what code it was just to make sure and it was a 90. what else should i do? im gonnta reset it again, fill the tank to full then see if it comes back right at half tank.
Old Feb 5, 2008 | 11:57 AM
Maui Built's Avatar
do an eletrical test on your purge valve and purge solenoid
Chewy Built !
Jun 8, 2008 10:18 AM
teggy2154
May 8, 2008 06:57 PM
honda_S
Aug 28, 2006 09:16 AM
R6Boy69
Nov 5, 2003 07:50 PM
Nikos
Sep 25, 2002 02:36 PM
