NEED HELP!!!! SPEAKER PROBLEM
Old Dec 9, 2007 | 12:05 PM
lPat's Avatar
Default NEED HELP!!!! SPEAKER PROBLEM
my 2 front door speakers are not working....
anybody know whats wrong? is there a fuse???
Old Dec 9, 2007 | 02:52 PM
WookinPaNub's Avatar
Default Re: NEED HELP!!!! SPEAKER PROBLEM (lPat)
Need more info. Do you have aftermarket speakers? Are they connected to an amp? If not I do not believe there is a fuse for just the front speakers. There is however a fuse on the amp(if they are amplified).
Check the wires behind the cd player and the speaker. Its possible they came loose or there is a short. The speakers could be blown, if you turn it up and they make some sound, thats probably it. Good Luck
Old Dec 9, 2007 | 03:07 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Pull your deck out and make sure all wires are connected, check your speakers and make sure the wires are connected
Old Dec 9, 2007 | 03:08 PM
Dogginator's Avatar
Daisy... Daisy...
I'll ask the obvious: have you adjusted the fade?
Old Dec 9, 2007 | 04:25 PM
all-mtr-teg's Avatar
Default Re: NEED HELP!!!! SPEAKER PROBLEM (Dogginator)
Ha, I swear, my boss, who has a PhD in Engineering had the same problem, his daughter pushed the right buttons and only the front speakers were on, he couldn't figure it out for like 2 days.
Old Dec 9, 2007 | 04:50 PM
lPat's Avatar
Default Re: NEED HELP!!!! SPEAKER PROBLEM (all-mtr-teg)
its a pioneer deck... aftermarket pioneer door speakers.
speakers work i tested thouse
wires are good i dont believe there is a short but if there is how would i know??
do i have to check with a multi meter
no the fade is not adjusted however i did adjust it to go to the front so i can see if the speaker would work and i get no sound.
i have a gsr and they come with stock tweeters on the door panel and the tweeters dont even work unless there just not loud
Old Dec 9, 2007 | 04:51 PM
To test the wires you can use a multimeter or DVOM and check for voltage in the speaker wires.
Nguyenv25
Audio / Security / Video
Feb 25, 2007 09:07 PM
dthug
Mar 14, 2006 08:15 AM
watacivic
Mar 13, 2004 12:45 PM
itsJDMyo
12
Nov 18, 2003 04:37 AM
acuraLSSE95
Nov 4, 2002 06:07 PM
