tricky intercooler plumbing
Old Dec 13, 2002 | 09:50 PM
WEPN R's Avatar
Default tricky intercooler plumbing
Im in the process of fabricating the intercooler charge pipes, I have opted to retain the a/c unit and find that on the passenger side (JDM), there is no room to position any pipework as all the a/c is in the way and a big unfrendly window washer refill bottle, how have you guys overcome this problem and and where have you routed your plumbing removing a/c is not an option
pics would be good
Old Dec 13, 2002 | 10:48 PM
Flamenco-T's Avatar
Default Re: tricky intercooler plumbing (WEPN R)
I took my windshied swuirter reservoir unit out....
I have a JDM front end and mounted the IC really really forward, so I had to do some trick, but it'll work...
use a few 90 deg bend piping to make the piping after and before the IC, it's easier to work with 90 deg bend, than having to find a U-bend that is wide enough to clear obstacles..
stan
Old Dec 14, 2002 | 01:54 PM
Foozball26's Avatar
Default Re: tricky intercooler plumbing (Flamenco-T)
If you look below the resivior there should be enough space to cut a hole in the plastic to slide the piping through, thats what I did.
This is on a 98 Civic.
wrx'n you
Sep 2, 2005 12:30 PM
forcedaccord95
Welding / Fabrication
May 13, 2005 08:19 PM
ID_ten_T
Aug 14, 2003 04:58 PM
superduperman
Jun 27, 2003 08:05 AM
