is my distributor bad??
Old Dec 17, 2002 | 05:41 AM
Carlito Brigante's Avatar
Default is my distributor bad??
rev hard kit
was running fine till recently.
timing is fine, the car has a bit of a rev cut at like 5500. i pulled the spark plug wire, when it hits this wall there is no spark.
we recently replaced the ignitor, ignition coil, plugs, fuel filter, rotor and cap. it was fine for a bit.
now its doing this again.
i get a check engine code of 92, which is the evap system failure im assuming this is due to all the gas and air just sitting there unsparked.
its fine, you see plenty of spark up to 5600 or so, then it stops like all spark. sometimes it goes past it and takes off hard like abitch. almost like another vtec.
a ricers dream lol.
any ideas, i think its the distributor, all grounds are fine, all items checked out fine.
maybe the wires??
Old Dec 17, 2002 | 07:10 AM
88_SC_CRX_Si's Avatar
New User
Default Re: is my distributor bad?? (turboed00si)
I think that code has something to do with emmission control, wheather it's causing the ECU to go into limp mode it another question tho...
You might try getting that fixed, before doing anything else tho.
Old Dec 17, 2002 | 07:18 AM
Default Re: is my distributor bad?? (88_SC_CRX_Si)
i did a evap check already last night. everything checked out fine. i used the helms manual to do so.
i even popped the fpr hose that goes to the intake manifold yesterday as well.
that has never happened before, i wasn't even in boost i was in vaccum.
wtf wtf wtf.
anybody give me some symtoms of a dying distributor, htech search sucks
Old Dec 17, 2002 | 11:29 PM
Jdm_Rice_Monster's Avatar
check the 2 screws that go to the coil, make sure they are tight, also double check all grounds, But I would bet the a wire inside the distributor is lose, happened to me, I felt real dumb after a lot of time a waisted tring to figure it out.
Old Dec 18, 2002 | 01:46 AM
rice a rona's Avatar
Default Re: is my distributor bad?? (JdmRiceMonster)
Maybe a bearing in the dist. is getting worn out and it needs a rebuild?
Old Dec 18, 2002 | 07:49 AM
Default Re: is my distributor bad?? (top notch)
thats my opinion. and it only happens at high rpms. so im thinking thats whats causing it.
reguardless its at honda today.
100G mile certified warranty
i just had to do the stock fix er upper last night.
GoSickemRobert
Engine Management and Tuning
Aug 3, 2011 11:07 AM
1badcrx
May 1, 2009 08:39 AM
EsCo_EsCo
Sep 29, 2008 08:25 AM
88 honda prelude
Jul 28, 2007 05:50 AM
CptCorN
Jan 17, 2005 06:33 AM
