Power FC w/ 3 bar map sensor
Has anyone got a Power Fc configured to use a 3 BAR map sensor? If so, what are the settings you used?
Guest
Posts: n/a
Re: Power FC w/ 3 bar map sensor (philo)
DAMN IT..... i talked to the guy with the RX-7 with the Power FC and the GM 3 Bar tonight, and i forgot to ask him what he had to do..... you have to change some setting, i can ask him next week, i am sure i will see him, he is always at the shop that is fabbing my IC piping
from what i understand it needs to go back to a PowerExcel shop and the one in Houston want $300 for to enable the 3bar sensor.
There is a place for map sensor settings...I just need to know the specs for it, and you don't have to pay PowerExel to get it!!!
Re: Power FC w/ 3 bar map sensor (MiraiZ)
you wont have to send your FC back to them. You will however had to alter the map. The cells will jsut have different values.
Re: Power FC w/ 3 bar map sensor (Boosted97Lude)
There is a few ways to do it. One way is to jsut tell it you have smaller injectors than what you really have. Or i you want to go and change all the values in the grid that is fine, it will work that way too. You can send it to XS to have them recalibrate everything which about all they will do is this. When you do it the way i said the #10 PR level will not be the crossover from vacuum to boost. It will be somewhere around 7 or 8.
i have that setup on my car.all you have to do is go into settings and chose PIM volt.scroll down to number 5 which is option 4.you don't have to do anything else.just make sure it stays on option 4 and hit prev to go back to wherever you want.
Re: Power FC w/ 3 bar map sensor (turbotypeR)
