Parts for an engine build?
Old Dec 16, 2002 | 11:35 AM
Anubyss's Avatar
Default Parts for an engine build?
I am going with GE, JE pistons, and Eagle rods. What other parts should be replaced while the block is being put in?
So far the list consists of: ARP head studs, water pump, accessory belts, timing belt, head gasket, exhaust gasket, new bearings, 3bar map sensor.......
__________________
Old Dec 16, 2002 | 12:18 PM
TeStUdO's Avatar
Default Re: Parts for an engine build? (Anubyss)
ARP rod bolts, get your gasket rebuild set from inlinefour.com. they had some decent prices when i got mine.
Old Dec 16, 2002 | 12:22 PM
swrdply400mrelay's Avatar
http://www.nipponpower.com
Also sells Cometic headgaskets
[Modified by swrdply400mrelay, 9:23 PM 12/16/2002]
Old Dec 16, 2002 | 12:26 PM
Anubyss's Avatar
Default Re: Parts for an engine build? (swrdply400mrelay)
I am going to use a stock head gasket.
Old Dec 16, 2002 | 01:57 PM
racerxadam's Avatar
oil pump
clutch? (you could potentially be making a lot more power)
Old Dec 16, 2002 | 02:26 PM
93LSivic's Avatar
Default Re: Parts for an engine build? (racerxadam)
T-belt tensioner and spring, new valve seals.
Old Dec 16, 2002 | 02:33 PM
Anubyss's Avatar
Default Re: Parts for an engine build? (93LSivic)
Well I have the ACT Xtreme kit already. I was asking more for what little things to change on the engine .
racerxadam what spring are you referring to?
Old Dec 16, 2002 | 02:49 PM
Evil EG's Avatar
bearings.
Old Dec 16, 2002 | 02:53 PM
Quaalude's Avatar
oil pump
Old Dec 16, 2002 | 04:05 PM
Anubyss's Avatar
Default Re: Parts for an engine build? (Quaalude)
Damn the parts alone is going to be a pretty penny.
Old Dec 16, 2002 | 04:18 PM
ekb18c's Avatar
It's not cheap!
edit- your not going to need to buy seperate rod bolts. The ones that come with your rods are good enough.
[Modified by ekb18c, 5:19 PM 12/16/2002]
Old Dec 16, 2002 | 04:21 PM
tSuperbike69's Avatar
You are going to want to buy:
oil pump
oil pump o' ring
water pump
oil strainer/ gasket
oil pan gasket
T-belt/ tensioner/spring
Head gasket
valve seals
oil control orfice oring
water pipe o ringS
t-stat
int/exh manifold gaskets
injector o rings
IAC gasket
Vtec sol. gasket
VC gasket kit
cam seals
cam plug
dist. oring
rear main seal
dist cap/rotor
I may be missing a couple but that is all I can think of right now. I also bought valve keepers, fuel filter, new hoses and TB gasket. I spent almost $400 with NO headgasket
Old Dec 16, 2002 | 04:38 PM
Anubyss's Avatar
Default Re: Parts for an engine build? (tSuperbike69)
Thanks. That seems like a good list to have.
angela_itr
May 21, 2005 01:51 PM
ludesleep
May 12, 2003 10:13 PM
lucas569
Aug 17, 2002 09:59 AM
schwett
Apr 24, 2002 08:37 PM
