can i do this to an inline pump?
Old Dec 15, 2002 | 04:59 PM
_Endless_'s Avatar
Default can i do this to an inline pump?
can i connect the inline pump directly to a 12v source like the battery for a few seconds to check if the pump is working? i connected mine directly to the battery for about 3 sec hoping to hear the motor run but unfortunately i didn't hear anything, is the pump dead?
Old Dec 15, 2002 | 05:22 PM
Evil EG's Avatar
Default Re: can i do this to an inline pump? (_Endless_)
did you ground it?
Old Dec 15, 2002 | 05:29 PM
DeepSi's Avatar
you need to hookup the ground also to complete the circuit.
Old Dec 15, 2002 | 06:07 PM
BoostedH23a1's Avatar
Default Re: can i do this to an inline pump? (DeepSi)
i think he askin will it be ok without fuel flowing through it..
Old Dec 15, 2002 | 06:12 PM
DeepSi's Avatar
Default Re: can i do this to an inline pump? (BoostedH23a1)
ohhhhh, wont it be fine if you put it in a bucket of water and see if it works, just make sure you let that sucker dry for a while, so you wont get any water in your engine.
Old Dec 15, 2002 | 06:16 PM
ChiBoy's Avatar
Testing it like that should be fine. The thing will normally see 12 volts anyway, so it doesn't matter if it gets it from the harness or the battery. Just make sure you have a good solid connection before you pronounce it dead.
Old Dec 15, 2002 | 10:25 PM
_Endless_'s Avatar
Default Re: can i do this to an inline pump? (ChiBoy)
will the motor of the pump run without fuel flowing through it? will it damage the pump if i test it without fuel flowing?
Old Dec 15, 2002 | 10:38 PM
M-EJ1's Avatar
Yes, it will run without fuel, no you won't damage it if it's just for a couple seconds, make sure you ground it or else it won't do anything.
Old Dec 15, 2002 | 11:29 PM
_Endless_'s Avatar
Default Re: can i do this to an inline pump? (M-EJ1)
ok. thanks guys. i hope the pump isn't broken but it's not working. i bought it used but the owner claims it was only used once and it shows since even the terminals are very clean. i even rolled up a paper and stick it on the pump's body hoping to hear the pump's motor whine but i hear nothing.the positive terminal is not tight since the thread is already damage by me but when i test the terminal there's 13+V so there's power but why is it not working? damn, this is frustrating. no wonder i'm leaning out. anyway, thanks again.
reebo
Classic Hondas
May 22, 2011 03:41 PM
LS AzZkIkr
Feb 23, 2008 02:06 PM
garyc17
Sep 16, 2006 10:24 AM
Justin Olson
Aug 22, 2005 04:03 PM
Cee_mon
13
Apr 27, 2005 12:08 PM
