What kind of welder are all you DIY'ers using? MIG/TIG?????
for my VW, i wanna make a 3" tb cause this 2.5dp and test pipe into 2.25 nuespeed catback aint cutting it, anyways, i am gonna get some bends form summit and weld them
will one of those 2-300 MIG welders from sears cut it? they are like 80-95 amps and some can weld from 3/16" to 1/4". a quarter inch is definetely enough, i just wanna be able to weld ic piping, exhaust, fmic mounting tabs etc.
I'll probably be doing work on B18Flip's car also, turbo gsr, anyways
is that thick enough for the flanges? do i weld the 5 bolt turbo flange right onto the mandrel bend?
any input would be cool, TIA
Re: What kind of welder are all you DIY'ers using? MIG/TIG????? (evoeone)
I use a gas torch. You can't weld stainless or aluminum with it, but if you learn with the gas torch, you can weld with anything later.
Sonny
Re: What kind of welder are all you DIY'ers using? MIG/TIG????? (javierb14)
from what i have seen my welder use, and he also says that MIG is easier, tig takes more skill
i just wanna small practical portable , probably MIG, enough for piping and small stuff, no framework or whatever, something for a beginner, but not obsolete either
Re: What kind of welder are all you DIY'ers using? MIG/TIG????? (falc0n)
tig 180sd millersyncrowave price is around 1200-1700 depending on where you order it from but it can do everything and for good price.
Re: What kind of welder are all you DIY'ers using? MIG/TIG????? (Sonny)
Sonny
Sonny
Re: What kind of welder are all you DIY'ers using? MIG/TIG????? (ekb18c)
OK, on my quest on here and VW vortex, i habe come to the conclusion of a wire feed MIG
now what size MIG welder do i need as far as amps?power etc.
i wanna spend like 300 max
Re: What kind of welder are all you DIY'ers using? MIG/TIG????? (boosted3g)
Miller 135 MIG is a good moderate duty welder. If you're going with a wire feed MIG, spend the little extra for some cover gas. Those gasless mig welds look like ***.
those start at $2000
and its extremely quite.
What is this crap?
true, but its light, portable, and automatically recognizes 3 different voltages.
for now, i dont really care about pretty welds or noise, i just wanna get these flanges attached to these mandrel bends and the o2 bungs and I'll be happy, just wanna make a functional exhaust, with decent welds and sealed, besides, i am sure the quality of the welds is in the welder, i'll buy some bends at auto zone and practice
[Modified by evoeone, 9:31 PM 12/16/2002]
air liquide is a little bit cheaper then miller and a great product.
dont cheap out. there really is no welder that is like middle of the line. u either got a pos or a good one.
as long as u got one with argon.co2 your set. MIG is so easy. i have a little 400$ eletric and i mean i can weld exhaust pipes with it but its a grind weld grind weld type job.. doesnt look pretty but it gets the job done.
Re: What kind of welder are all you DIY'ers using? MIG/TIG????? (shortyz)
like i said, i want function, not aiming for pretty, and i am sure i can attain that for 300 bucks....i hope so
pretty welds are good welds. And good welds are pretty. sorry but theres no way around it.
Re: What kind of welder are all you DIY'ers using? MIG/TIG????? (TREVER)
if you just want something cheap, then go buy a campell-hausfeld from WAl-mart...get the wire feed fllux welder...it's like 150 bucks and will get the job done. Don't complain when those flux-cored weld like cotage cheese
Re: What kind of welder are all you DIY'ers using? MIG/TIG????? (paul_vang)
I have the new Lincoln from home depot I can weld aliminum and stainless steel. I could not live without tools. Welding is one of the best things out their but don't forget about brazing it also comes very handy and looks really clean. I always braze when it comes to intercoolers and fuel tanks, and some times piping.
now for exhaust, do you need to have perfect and pretty welds?if your welds come out really thick and ugly, but sealed and functional, can you dremel the excess weld off, or would that make it weaker
i use a gasless wirefeed MIG, and i can get some damn fine welds out of it. Don;t know what you guys are doing wrong to ahve it look like swiss cheese.
A gassless wirefeed will work just fine for the welding you wnat to do
If you havn't welded before get scrap metal to practice on, start with thicker pieces so you don;t burn holes and get frustrated
And don;t forget a good mask/helmet, sunglassses don;t cut it (Don;t ask how i know )
Too bad your not local cause i am selling mine to move up to bigger and better
[Modified by zc911, 8:57 PM 12/17/2002]
Re: What kind of welder are all you DIY'ers using? MIG/TIG????? (zc911)
Re: What kind of welder are all you DIY'ers using? MIG/TIG????? (racerxadam)
i also found that welding at night outside was easier becuase there was no other light around and no glare in the helmet, wich makes it MUCH eaier to see what you are doing
