Pressure drop due to intercooler efficiency.
Old Dec 15, 2002 | 07:25 PM
vtec.dc2's Avatar
Default Pressure drop due to intercooler efficiency.
If to consider that average pressure drop through intercooler is 10-15%, based on that, should I run 10-15% higher boost? If I want to run 5psi, should i run 6 or more so it turns into 5psi after going through intercooler?
Someone explain this. Thanks
Old Dec 15, 2002 | 07:41 PM
SJP0tato's Avatar
Default Re: Pressure drop due to intercooler efficiency. (vtec.dc2)
It depends on where your wastegate actuator source is coming from. If it's tapped into the intake manifold, just leave it as is, it'll compensate for the pressure drop automatically. If you have it tapped into the turbo housing, you'll have to adjust the boost to compensate.
Ryan P.
bambam
Mar 27, 2005 04:53 PM
integranator
Nov 22, 2002 12:37 AM
DSF
Apr 22, 2002 03:39 AM
grnsol
Feb 20, 2002 10:23 AM
