how much is safe on a d16 w/.....
Old Dec 14, 2002 | 09:01 AM
FormulaEJ8's Avatar
Default how much is safe on a d16 w/.....
Im building a newer d16y8 longblock for a turbo set-up to put into my ex sedan and so far i have decided on the greddy kit. lately i have seen people only run about 5.5 psi on it, but with the internals im adding im wondering how much boost this things gonna handle? eagle rods,wiseco pistons,metal gasket,skunk cam,and possibly springs and ti retainers. As for my fuel:b&m fpr,aem rail,rc 310 injectors. sorry for the long post!
Old Dec 14, 2002 | 09:20 AM
Jefnes's Avatar
Default Re: how much is safe on a d16 w/..... (9d6ek)
Your limiting factor in your set-up (as you listed) is you injector size.
310 cc is quite small for the power that that hardware can take.
the other guys run 5.5 psi because they have stock internals.
But with the set-up as you have posted you can run 8-10 psi. (small injectors)
That hardware with say 550cc injectors could handle 15-18 psi.
oh yeah, don't forget to buy a good fuel pump. Walbro 255hp
A few other items: ARP head studs. Hondata ECU crack (enables you to re-write
the factory chip to run big injectors and boost, i.e. no piggyback stuff).
You could play the high fuel pressure/small injectros game if you wish
instead of buying big injectors...
Jeffrey Atwood BSME
Old Dec 14, 2002 | 10:08 AM
Boltz's Avatar
dont worry, that post wasnt long at all...... the 310cc arent the most limiting factor you have, your greddy blue box is... also with the amount of boost you will be running you dont really need springs and retainers... i also wouldnt get that skunk cam, its meant for NA, if you really want a turbo cam that bad id and are super antzy go with crower, but i hope your not that antzy because crower isnt very good quality. fi yuo really want a cam wait for hondasaver, hes making a d cam. also ditch the fuel rail, its not nesscary yet.... ok so just get the greddy kit rig up a side mount intercooler, get a fuel pump, injectors, nathans internals, and hondata... use all that money you saved from ditching the parts i named and buy the hondata, also nathans internals are only 400+ so youll save $$ there... he says you can run over 1 bar on tose
Old Dec 14, 2002 | 01:22 PM
swrdply400mrelay's Avatar
The GReddy 15G does not make any more power after 14psi. You can use 310cc injectors if you have an FMU and an AFC to tune them with.
Old Dec 14, 2002 | 01:24 PM
TheShocker's Avatar
Default Re: how much is safe on a d16 w/..... (swrdply400mrelay)
I'd go with a larger turbo, larger injectors and a Hondata. Those things in addition to what you've already listed could make a lot of power.
Mephistopheles
Feb 15, 2021 05:17 PM
Freshdot
Apr 12, 2011 02:50 PM
jamesfawcett
Apr 13, 2010 01:33 AM
B16Civic93
Mar 7, 2005 11:00 AM
freakie
Nov 8, 2001 08:39 AM
