Thick Headgasket
Old Dec 13, 2002 | 09:54 PM
Project_SOHC_EX's Avatar
Default Thick Headgasket
Guys I need some help. I want to lower the compression on m stock D16Y8 from 9.6:1 to say maybe 9.2:1. My setup is gonna be a TD04H Mitsubishi turbocharger on a stock SOHC VTEC engine with 440cc injectors an upgraded Walbro fuel pump some colder spark plugs and wires and maybe a blockguard gonna run 10-12 pounds and tuned by Hondata and my goodfriend Jeffrey Atwood. So in essence I need to know where to find a good-thick aftermarket headgasket.
Old Dec 14, 2002 | 04:42 AM
ekb18c's Avatar
Default Re: Thick Headgasket (Project_SOHC_EX)
Why lower it? Keep it the way it is, since you are going to get it tuned. 9.6:1 is already considered low compression.
Compression is your turbo's best friend!
Old Dec 14, 2002 | 11:07 AM
Default Re: Thick Headgasket (ekb18c)
Only because I would like to run 10psi of boost safely right now this is my only motor and I can't afford to blow this **** up. I do agree that 9.6:1 is considered low but I just wanna be on the safe side. Do you know of any good headgaskets?
Old Dec 14, 2002 | 11:31 AM
MayhemSi's Avatar
Invest in a blockgaurd and some tuning instead. I think this topic just came up a few days ago, too?
Old Dec 14, 2002 | 02:32 PM
ekb18c's Avatar
get one from cosmetic if you really want to go with a headgasket.
Old Dec 14, 2002 | 04:11 PM
avividmemory's Avatar
yup, keep it where it is and get a blockguard...i will be running slightly over 10:1 cuz it will make more power on lower boost...
Old Dec 14, 2002 | 07:39 PM
333's Avatar
333
Default Re: Thick Headgasket (SpoolinLS)
Just keep the stock gasket. Any thing else you are going to have to o- ring the block. Plus, that I believe would be your weakest point. You don't want to blow a headgasket, maybe consider some arp head bolts and stock honda head gasket. That's what I have.
Old Dec 15, 2002 | 12:20 PM
Default Re: Thick Headgasket (333)
Cool, thanks Greg. I need to find some arp head bolts.
Old Dec 15, 2002 | 12:44 PM
earl's Avatar
Instead of dropping the compression, why not just hold the boost to 8 lbs and get the same power? That will save you the cost of a new gasket.
Old Dec 15, 2002 | 03:30 PM
turbod16y7vtec's Avatar
Default Re: Thick Headgasket (earl)
go with the mr. gasket.. i did it on mine u have to knotch the block a lil to get the pins that hold the gasket together to hold but its great i love it works good good.. and mine is about 2mm thick so.. go with mr gaskets many 's
f1 vtec
Jun 25, 2009 08:10 PM
egeeb16
May 5, 2007 09:34 AM
Nextelbuddy
Feb 6, 2004 10:29 AM
n1neb4ll
Oct 12, 2003 10:10 AM
ILOVEGIRLS
Jul 10, 2001 10:34 PM
