NX direct port 80 shot on this setup
Old Dec 13, 2002 | 04:49 PM
EFing8's Avatar
Default NX direct port 80 shot on this setup
I have a B16a1 w/ the following in my 88 CRX HF
ITR cams
ITR valvesprings
OBD0 - OBD1 conversion
Chipped P28 to DOHC
V-AFC.
Blah blah other bolt ons...
I want to add CTR pistons to the motor. With the 11:1 compression, how would this car like the 80 shot of nitrous? I am only considering Direct port. I have used zex and I know it is a beginer system. I want some serious power.
Old Dec 13, 2002 | 05:13 PM
PM-Performance's Avatar
Default Re: NX direct port 80 shot on this setup (CND_CRX)
itll work great , just watch the fuel and youll fly,
Old Dec 13, 2002 | 05:18 PM
DaNish's Avatar
Default Re: NX direct port 80 shot on this setup (itr206)
i would get some fuel upgrades ie fuel pump, adj fpr and a fuel rail and hit the dyno for some tuning
Old Dec 13, 2002 | 05:38 PM
EFing8's Avatar
Default Re: NX direct port 80 shot on this setup (X DaNish X)
That was the plan all along. A walbro 255 and mabey some bigger injectors and off to the dyno.
Old Dec 13, 2002 | 06:39 PM
abraunb16's Avatar
New User
You don't need bigger injectors to run that setup. If you go direct port just make sure to get a bigger fuel jet to help add the extra fuel while squeezing. The direct port is going to be harder on the motor, so keep that in mind.
Old Dec 13, 2002 | 06:53 PM
rOby's Avatar
Default Re: NX direct port 80 shot on this setup (abraunb16)
dont bother w/ injectors or higher fuel jets. just get it dyno'd and find out what 80hp really equates to jet wise. if your going to build the head, jump to a 100 shot. id invest in an ignition..ie msd digi 6! by far the best for ur application. its got a lotta features especially suited for n20 and drag racing. if ya need a digi 6 i gotta sell mine so let me know, pm me if ya got any ?'s or need a new nx kit cheap.
roby
Old Dec 13, 2002 | 06:59 PM
dvp95's Avatar
Default Re: NX direct port 80 shot on this setup (roby)
Hey can you tell me the jet sizes for a NX 80 shot? I thought 100 was the smallest, but maybe 80 is. Thanks, 100 was 26/14.
Old Dec 13, 2002 | 07:55 PM
AR Fab's Avatar
Default Re: NX direct port 80 shot on this setup (dvp95)
80 is only available at lower fuel pressures...so this would require a second fuel system.....
Howard
Foowee
Jun 8, 2008 12:08 PM
DA-MAX
Jul 13, 2005 01:59 AM
PolyPill
Dec 15, 2004 01:48 PM
laughinxxx
Aug 18, 2001 10:32 AM
