ls/vtec turbo w/obd-0 (management choices)
i need some opinions on which management choices i have for a turbocharged ls/vtec w/obd-o. i know the new hondata only cater's to obd-1 same w/aem ems. without going to something as drastic as haltech/accel dfi etc... or race specific stand-alone. what else can i use? am i limited to zdyne? i am also thinking maybe sds? anyhelp would be cool, thanks
Re: ls/vtec turbo w/obd-0 (speeddave)
Hondata works for OBD-0.
PW0 and PR3.
You just use the 'old' stuff, stage 2,3,4. All the same 'features' of the
current s200 just not as polished.
Jeffrey Atwood
PW0 and PR3.
Jeffrey Atwood
Re: ls/vtec turbo w/obd-0 (Jefnes)
Why not use the Z-dyne ?, I have put it on many cars, supercharged and turbo ( Inc my own) and it has been great. The tunes that come with it are so close you will be up and running in 5 mins!
Re: ls/vtec turbo w/obd-0 (CRVRX)
does both the early hondata's and the zdyne require both o2 sensors and the knock sensor? thanks for the help guys!
Re: ls/vtec turbo w/obd-0 (badCRX)
Hondata needs what the stock ECU needs...
It is not a different ecu it IS your stock ecu with a 'new' chip.
But you can dis-able the O2 sensors and run open loop if you need.
Jeffrey Atwood
Jeffrey Atwood
If I were you I'd go full standalone. I'm currently using the DTA unit. Wiring wouldn't be that hard to do and the price is very reasonable. I can get a unit for about $1300 CDN.
Re: ls/vtec turbo w/obd-0 (integracon)
You don't HAVE to disable it, right?
What's the advantage?
TIA
TIA
Re: ls/vtec turbo w/obd-0 (Speed PHreak)
so to run one of the older hondata obd-0 programs...what exactly do you need, one of those two ecu's listed....and what else?
Re: ls/vtec turbo w/obd-0 (B16B-EF9)
i'm shooting for the 300-350hp range, i was thinking of the hack, but i was also interested in the smc, but i still have the hurdle of the 2nd o2 sensor and the knock sensor to get over with the pr3 ecu.
Re: ls/vtec turbo w/obd-0 (sporkcrx)
That's it !!!
Jeffrey Atwood
projectef
04-26-2007 05:52 PM
dem0nk1d
02-14-2007 04:03 PM
