going to dyno today--> tuning SMC
Old Dec 17, 2002 | 05:56 AM
glagola1's Avatar
Default going to dyno today--> tuning SMC
Hey I'm going to a dyno tonight to tune my SMC. I've got a B18B1 with an IHI turbo @ 10psi. I'm also running 450cc/min injectors and a 255 lph pump. Is there anything I should know before I go?
I've street tuned the best I can so I think I've got a good base to start from. Also I've noticed that the dials on the SMC are very sensitive.
I'll post the graphs tommorow so stay tuned.
Old Dec 17, 2002 | 05:59 AM
lsvtec101's Avatar
Default Re: going to dyno today--> tuning SMC (glagola1)
dude let me know how it goes.. got a garrett t3 here with some rc440's (if the kid ever ships em) 255lph pump... what kind of a/f gauge are you using? post numbers asap! same exact setup but i got a 9l/b flywheel .. this will be intresting.
Old Dec 17, 2002 | 06:05 AM
glagola1's Avatar
Default Re: going to dyno today--> tuning SMC (aemcivic_02917)
I've got an Apexi turbo timer with the a/f meter built in but I'm using a wide band at the dyno to tune of course. I'm also running a Greddy FMIC and a Thermal 2.5" exhaust and a 2.5" test pipe. Oh, I've got an 11lb flywheel.
I'm using the Apexi turbo kit for the D16Z6 so I am really curious to see what kind of shape the graph has.
Old Dec 18, 2002 | 08:31 AM
lsvtec101's Avatar
nice get any numbers yet?
Old Dec 18, 2002 | 08:35 AM
glagola1's Avatar
https://honda-tech.com/zerothread?id=363036
The smc blows. I gotta think of something else.
[Modified by glagola1, 5:37 PM 12/18/2002]
Old Dec 18, 2002 | 09:17 AM
Honda4CX-T's Avatar
What are you talking about ???
The SMC "blows" ... backup what you are saying please ... (unless this is sarcasm)
I think under the circumstances those are pretty good numbers considering this: "Apexi SOHC kit". You do know SMC or Hondata (11psi for Hondata) runs at 10psi MAX with either 440cc - 550cc's combo. After that you will need a 3 bar MAP sensor for Hondata to see mor PSI.
[Modified by Honda4CX-R, 1:24 PM 12/18/2002]
Old Dec 18, 2002 | 09:39 AM
glagola1's Avatar
Default Re: going to dyno today--> tuning SMC (Honda4CX-R)
Well, here's the deal with the SMC. If you look at the dyno graph of my set up you'll see that the boost comes on between 2.5-3k rpms. Now I tried and tried to dial in my a/f but I could not do it. I need the fuel cut back at 2.5k and majorly added at 4k.
I am running 450cc/min injectors at stock fuel pressure with a 255lph pump. When I turn up the smc all the way rich I can not get any richer than 13.5:1 around 3.5-4k rpm. That sucks. Also when I do this I flood the motor before boost comes on around 2.5K rpms. The SMC has only one dial for 1.5k-4k rpms so there inlies my problem.
You dig? Maybe if I had a big fat lazy turbo that spooled at 4k it wouldn't be a problem but as it stands, I'm lean in some areas and rich in others and I've only got one dial to work with for that rpm range.
[Modified by glagola1, 6:40 PM 12/18/2002]
Old Dec 18, 2002 | 09:41 AM
lsvtec101's Avatar
think ill stick to a safc...
Old Dec 18, 2002 | 09:48 AM
glagola1's Avatar
I think that might be a good idea that I may have to try before jumping into the hondata pool.
Old Dec 18, 2002 | 10:03 AM
sporkcrx's Avatar
I'll be going to the dyno soon to tune my SMC, 450's and a 255lph intank also...my t25 spools quick too so i hope i dont have too many problems
Old Dec 18, 2002 | 10:25 AM
glagola1's Avatar
Default Re: going to dyno today--> tuning SMC (sporkcrx)
Yeah, maybe zip will realize this and give more dials in the future.
Old Dec 18, 2002 | 10:29 AM
johnzm's Avatar
nice dyno man. i knew that thing would post sick #'s after riding in that beats
Old Dec 18, 2002 | 10:30 AM
swrdply400mrelay's Avatar
Those are some pretty good numbers! But go with an AFC.
Old Dec 18, 2002 | 12:30 PM
SIK IN DA HED's Avatar
New User
Default Re: going to dyno today--> tuning SMC (swrdply400mrelay)
one negative outcome of the SMC... one reason why its good to wait and see how it works for everyone.. not just a few. for some... Zip's SMC is a good idea... for others, it might not be. everyones setup is different... remember that.
Old Dec 18, 2002 | 12:34 PM
glagola1's Avatar
Default Re: going to dyno today--> tuning SMC (dlplayboy)
word
jdm-gsr
Feb 22, 2010 02:41 AM
acrocat
Mar 16, 2009 08:42 AM
TylerC161
Aug 24, 2007 06:43 AM
DOHCarp
Aug 23, 2003 04:17 PM
98civicEX
Apr 22, 2002 02:43 PM
