LS turbo, What do I need for fuel system?
I am going to turbo my LS motor. First i want to upgrade the fuel system. What exactly do I need to do this? How many PSI can I run on the stock motor with the upgraded fuel system?
Re: LS turbo, What do I need for fuel system? (dlplayboy)
dont forget... tuning is the key.
He's right though. You can have the best fuel management out there but if you don't know how to tune it then it wont do you any good. Your engine will fail just the same.
What hondata would I need (and where are they sold)? Also, What sized injectors for 12psi max boost?
Re: LS turbo, What do I need for fuel system? (civcexcoupeblack)
You can purchase hondata from one of the following dealers on this page:
http://www.hondata.com/contact.html
Get 440cc injectors.
Smarter than you
Re: LS turbo, What do I need for fuel system? (ekb18c)
I would go w/ 550's for 12psi. I run 12psi stock motor everything is ok but its all about having a safe a/f and most importantly running safe timing.
