****need help with turbo install****
will anyone help me out that has AIM?
ive tried imagestation, etc. for uploading pics but it never works for me. would anyone let me IM them 2 pictures of my turbo kit setup i have labeled so i can learn what i need to do about my current setup, i think i am missing pieces, or am retarded... thanks in advance to anyone that wants to lend a hand.. ...
PLEASE HELP
IM BroPo9420 : :
THANKS
AIM ME @ BROPO9420
[Modified by Civic420, 10:32 PM 12/16/2002]
PLEASE HELP
IM BroPo9420 : :
THANKS
AIM ME @ BROPO9420
Re: ****need help with turbo install**** (The Mole)
here she is... i dont know how to get the circular piece into that rectangluar thing for the exit of the oil on the turbine.... thanks for the help!
Re: ****need help with turbo install**** (Civic420)
you need an oil outlet flange. you can get it here, $13. http://www.roadraceengineering.com/f...andgaskets.htm
DAMN! Talk about not 56k friendly at least use .jpg's.
The part you need is here
http://64.225.76.178/main.htm
Part Number is 20259
But anyway where in IL are you, if your close and need any help with the install I could give you a hand.
AIM: TurboGSR2000
[Modified by BVM, 11:20 PM 12/16/2002]
AIM: TurboGSR2000
1. Yes you need the flange mentioned above
2. Yes the part that you say weld to oil pan is correct.
3. For non-IC turbos there are only 3 pipes, but for some reason those dont look like it. The bottom one hooks up to the turbo. the top one connects to the TB. the middle one looks like a pipe for an IC piping.
Re: ****need help with turbo install**** (Ivan)
thanks to everyone that replied... im gonna see if viren will quick ship me one of those oil flanges now. my only problem as of now that i still have is my intercooler piping... also, where does it hook through on the drivers side? i know it doesnt go through where a/c is supposed to be and the only other hole i have is for my wiper fluid... ill take a pic of that today and get it up aound 2pm cnt..
thanks
thanks
BVM - i am located in geneva(60134), which is a small town. it borders st. charles.... lemme know how far you are
justin
justin
I live in yorkville (60560) which is like 15 - 20 mins away.
[Modified by BVM, 7:54 AM 12/17/2002]
the piping you have is only for the outlet of IC to TB. I ordered mine from viren too. that 90degree bend goes between the other two pipes. you'll be able to tell when you get them on there.
BTW when you install it, let me know if if fits right. for some reason mine wasnt angled correctly right at the tb bend
i dont know if you can see how its bent in some.
Re: ****need help with turbo install**** (TurboedGSR)
That RRE flange is an aluminum piece with a 1/2" NPT thread on it. It comes with a 1/2" NPT to 5/8" barbed brass adapter. The AN fitting you have will not thread into the RRE flange, so you need to get an adapter to go from 1/2" NPT to your AN fitting if you want to use the RRE flange.
Re: ****need help with turbo install**** (Wanna lude too.)
TurboedGSR - thanks for the help dude, so i take it i am missing 2 or more pieces that connect the inlet side of the intercooler to the output of the compressor?
bvm - thanks for the help meng! i should be ok with me and my mechanic working on it, but another set of hands is always welcome if you would like to join us.
Wanna lude too - small world huh? is your prelude stock? i have no problem meeting up sometime, im also starting a exclusive car club next season, what i am excluding is slow cars. lol.. how old are you? do you still go to the stc high school(s)?
later
later
Here is what my IC piping looked after I got it all finished and had it welded. You can get an idea of what all the pipes are that you will need. It is only missing the pipe that came off the turbo outlet. You should be able to understand where the other pieces fit in the car.
Justin
Justin
My ludes got i/h/e/ pullies and vafc. My best is a 14.9 and that was before the vafc and header. I want to go turbo and would love to check your car out. I'm 20 and i just started making fat cash at the Chillis across from the mall. I went to Kaneland and know i'm at Waubonsee.
ekb16a
59
06-21-2007 10:02 PM
