idle change with compression?
Old Dec 17, 2002 | 07:32 AM
gsrcivict's Avatar
Default idle change with compression?
Will the idle change when you lower the compression? I just rebuilt my gsr with je pistons 9:1 compression and a bored 20 over block. Ever since it as put back together it has been idleing funny. It kinda sounds like its camming. I do have 2001 itr cams but it didnt idle funny before the rebuild. runs fne but just sits at like 750rpm and sounds funny. Anbody know what it could be? Thanx!
Gabe
Old Dec 17, 2002 | 07:35 AM
TURBO18's Avatar
Default Re: idle change with compression? (gsrcivict)
Compression won't really change the way a car idles. Check you cam & ignition timing.
Old Dec 17, 2002 | 08:23 AM
gsrcivict's Avatar
Default Re: idle change with compression? (TURBO18)
what you mean by "wont really change" I will check my timing..it should be stock right? with turbo and colder plugs? thanx
Old Dec 17, 2002 | 10:35 AM
turbosol's Avatar
Ever since I put an ITR head on my B16 it has idled lumpy, then I rebuilt every thing (bored 020 over, 9:1 JEs) and it still idled lumpy. Now I bought a 00 Si and changed the head over and this car idles lumpy. I run my vavles pretty tight and figure it's just the cams??? But I don't remember my ITR idling lumpy though.
daboy155
Jul 28, 2018 02:45 PM
1epmugenlude
Jan 8, 2006 05:47 PM
MidoriEK4
Jun 3, 2003 05:39 AM
dbman96
May 29, 2002 09:26 AM
Regular Series
May 12, 2002 01:03 PM
