can i use OEM headgasket with 81.5mm bore ??
Re: can i use OEM headgasket with 81.5mm bore ?? (C-Westin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-Westin »</TD></TR><TR><TD CLASS="quote">as the topic says
will be able to use it ???
thanks guys </TD></TR></TABLE>
That means you can run a stock bore(81.0mm) headgasket on a block with a 81.5mm bore?
I need to know this too.
Re: can i use OEM headgasket with 81.5mm bore ?? (simike)
U can run 81 MM gasket all the way up before 82mm.
Then an 82MM can almost go to 83MM and so on.....
I called Golden Eagle to verify this recently.
Master23
03-08-2006 01:18 PM
