JG/Edelbrock Intake manifold... WHICH THROTTLE CABLE ?
I have the JG/Edelbrock Intake manifold on my b16 head.
Which throttle cable am I supposed to use? I tried the LS... didnt work. I tried type R and the Type R peice that holds it.... didnt work.
So which throttle cable or other peices am I supposed to use?
Re: JG/Edelbrock Intake manifold... WHICH THROTTLE CABLE ? (TurboIntegra)
Im my crx with a gsr motor, I used the type r bracket with a ls cable. It doesnt line up perfectly though. You can also use the gsr TB bracket with a gsr cable. That way all the mounting is done on the tb...
Re: JG/Edelbrock Intake manifold... WHICH THROTTLE CABLE ? (Muckman)
I've got a 99 si and I'm using the stock cable/bracket. It's angled a little bit but it works flawlessly.
I modified the arm that bolts to the intake manifold to hold the throttle cable.. worked like a charm, did the same on my friends aebs intake mani setup.
Re: JG/Edelbrock Intake manifold... WHICH THROTTLE CABLE ? (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blusi »</TD></TR><TR><TD CLASS="quote">I've got a 99 si and I'm using the stock cable/bracket. It's angled a little bit but it works flawlessly.</TD></TR></TABLE>
really? I was trying to do that and I couldn't get it to work... I bought an integra bracket using the b16 cable... still didn't work...
here's my integra bracket that has more mods after this pic to make it work
the cable is pretty much where it needs to be in the pic. I have it close, but there's still some angle... who ever said the integra bracket bolts right up is full of it...
I'd like to see pics of 99bluesi cable/bracket... cause the stock one has the mounting tab on the opposite side from the pic above, making it way off.
Re: JG/Edelbrock Intake manifold... WHICH THROTTLE CABLE ? (turbosi03)
Not the greatest picture, but the stock cable/bracket/throttlebody all work together on the Victor X.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Is it on the throttle body or the intake manifold? Can you post a pic?</TD></TR></TABLE>
Il try and do that...
Its mounted to the IM, the bracket I made just moves the stock bracket to the left about an inch.
Go here: http://www.acuraoemparts.com/d...ch=no
Order part #6 the GSR throttle cable bracket, then order a GSR throttle cable....this is what I did
Re: JG/Edelbrock Intake manifold... WHICH THROTTLE CABLE ? (Boosted2K)
i put the regulator on before I put the rail on. I had to put a little bend on the bottom piece to fit the fuel return on, but it works great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted2K »</TD></TR><TR><TD CLASS="quote">Go here: http://www.acuraoemparts.com/d...ch=no
Order part #6 the GSR throttle cable bracket, then order a GSR throttle cable....this is what I did </TD></TR></TABLE>
Exactly what I did.... and it works great. I also used an LS throttle pulley on my GSR throttle body.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">It looks like the Si throttle bracket does NOT need to be modified. </TD></TR></TABLE>
Mine is a 99 SI throttle bracket and cable and it had to be modified to work with my GSR manifold.
THEUSED
12-29-2005 08:30 PM
Autoworks
03-10-2005 04:19 PM
Ls1 FD3s
01-15-2005 10:51 PM
SpeedDreamz.com
05-31-2004 06:37 AM
