hondata and injectors
Old Dec 14, 2002 | 09:09 PM
civcexcoupeblack's Avatar
Default hondata and injectors
In my Ls motor, I have a hondata 2b and what injectors do I need. I was thinkning 440's, but which ones? Also, do I need peak and hold, or saturated injectors. What is the difference. I plan on running no more than 10psi on stock internals.
[Modified by civcexcoupeblack, 10:11 PM 12/14/2002]
Old Dec 14, 2002 | 09:27 PM
boostaholic's Avatar
Default Re: hondata and injectors (civcexcoupeblack)
Without a resistor box, you'll have to stick with saturated injectors. 440's are fine for your setup.
Old Dec 14, 2002 | 10:05 PM
Mr.DC2TurBo's Avatar
with 10psi I would rather use the safc with the aem fpr and 440cc sat injectors. But if you already have the hondata, then sat. injectors are the way I would go. Ez to install and no worries about having a used resister box that may not work right. RC injectors arent that expensive and will only be around 60 bucks more than the dsm and resister box.
Old Dec 15, 2002 | 07:49 AM
Default Re: hondata and injectors (Dr.TurBo2006)
Would I need to upgrade my fuel pump also?
Old Dec 16, 2002 | 01:16 PM
yes, intak pump will be fine.
96redgsr
Jul 21, 2004 09:46 PM
integracivic94
Dec 30, 2003 06:49 AM
Hoodwinked
Aug 23, 2003 12:32 AM
GOLDBERG
May 6, 2003 05:00 PM
PM-Performance
Nov 4, 2002 08:40 AM
