Truth or Hearsay
Old May 14, 2004 | 10:58 AM
H.crx-si
Guest
Posts: n/a
Default Truth or Hearsay
I plan on turboing my d16a6 motor and I was talking to a good friend of mine today who has been running a automotive shop for quite sometime they deal with rebuilds/repairs and machining. He mentioned that the d16a6 is a high compression motor and by running a junkyard setup most turbos are made for low compression engines and that a turbo would need a consistent supply of oil and it wont simply pull the oil it needs like a vacume through the oil feed line, he thinks I'll blow it up. I only plan to run 5-6psi and I'm gonna ghettodyne to compensate for fuel but he got me a little nervous. My motor has 150,000miles but still pulls like a champ.
Old May 14, 2004 | 11:02 AM
Mad Cow's Avatar
Default Re: Truth or Hearsay (H.crx-si)
Just goes to show that you don't have to be smart to rebuild an engine.
I want some of whatever he's smoking.
Old May 14, 2004 | 11:04 AM
boostsohfast's Avatar
The d16a6 only has a 9.1:1 compression ratio... So its really not even that high... You also won't have a problem getting sufficient oil with a "T" in the back of the block.
Ekasey's Avatar
Default Re: Truth or Hearsay (MadCow the Transvestike.)
yeah hes got the good stuff, the turbo will get plenty of oil just add an extra 1/2 quart to compensate for the lines and the motor wont blow up if its tuned well and drive conservativley
Old May 14, 2004 | 11:09 AM
SleepyEG's Avatar
Default Re: Truth or Hearsay (eLusive ek4)
I know you don't smoke weed...I know this, but I'm gonna git you highhh today, cuz it's Friday, you aint got no job, and you aint got **** to do!
Old May 14, 2004 | 11:38 AM
H.crx-si
Guest
Posts: n/a
Ok so run a T off the back of the block so the oil is diverted both ways and just run a bit more oil and she should be all good. I think I'm gonna go ahead with it anyway. I'm gonna run a little wee turbo with low boost unless it spikes......thats another thing what the usual cause of boost spike? I wanna make this as safe as possible. I'm running it a bit rich so I dont get any detenation as well. As far as the oil feed line is do I run a direct route to the oil pan and another direct route to the T behind the block is that how it runs?
Old May 14, 2004 | 11:43 AM
SleepyEG's Avatar
Default Re: (H.crx-si)
where on the east coast are you?
Old May 14, 2004 | 01:47 PM
H.crx-si
Guest
Posts: n/a
eastern canada, nova scotia
Old May 14, 2004 | 02:06 PM
baphomet's Avatar
I was expecting a tranny question.
Old May 14, 2004 | 02:13 PM
cheapturbolines.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.crx-si &raquo;</TD></TR><TR><TD CLASS="quote">Ok so run a T off the back of the block so the oil is diverted both ways and just run a bit more oil and she should be all good. I think I'm gonna go ahead with it anyway. I'm gonna run a little wee turbo with low boost unless it spikes......thats another thing what the usual cause of boost spike? I wanna make this as safe as possible. I'm running it a bit rich so I dont get any detenation as well. As far as the oil feed line is do I run a direct route to the oil pan and another direct route to the T behind the block is that how it runs?</TD></TR></TABLE>
You don't really need to run much more oil. Just fill it up in between the 2 marks close to the top on the oil dip stick just as you would if you were NA. The lines and the turbo really don't hold much oil inside them.
For the feed line you wanna "T" it into it to a oil source on the back of block. The return line goes to the pan.
chris G.
Old May 14, 2004 | 08:05 PM
H.crx-si
Guest
Posts: n/a
thx cheapturbolines.com that helps alot
CoolFoolIT
42
Jan 19, 2012 09:23 PM
IntegraType-R
Oct 15, 2007 02:28 PM
xEnderx
Jan 4, 2006 06:38 PM
livinlow
May 28, 2005 01:10 PM
ah789454
Nov 14, 2004 03:03 PM
