ARP or AEBS head studs
Old May 14, 2004 | 12:11 PM
Dublocivic's Avatar
Default ARP or AEBS head studs
Which would you choose for a high hp application? The only advantage I can see is that the AEBS have a dimple so you dont bottom out the threads.. but as far as strength goes which would you choose? Are they comparable in tensile strength? I know the ARP bolts are 8740 chromoly(sp) steel with 190,000 psi tensile strength, but what about AEBS?
any input would be great.
Old May 14, 2004 | 12:42 PM
PM-Performance's Avatar
Default Re: ARP or AEBS head studs (Dublocivic)
ARP has been around forever and used in almost every hi HP application out there. They work for me .
But the AEBS bandwagon will jump on soon im sure
Old May 14, 2004 | 12:53 PM
BodyKits NW's Avatar
Default Re: ARP or AEBS head studs (itr206)
If I had the choice I would run the AEBS. Both make great head studs and it is more of a matter of preference than anything. They are super beefy and the dimple design preloads all the theads. I think ARP has changed there design and there head studs now have the same feature. I have used the old ARP headstuds with no problems. So either one should be fine, but for my next engine I am going to use the AEBS.
Old May 14, 2004 | 03:38 PM
Dublocivic's Avatar
Default Re: ARP or AEBS head studs (BodyKits NW)
Thanks for the replies. I was guessing they were comparable just didnt know if one had an advantage over the other strength-wise.
kornerk12
Feb 7, 2007 09:03 PM
d16dcoe45
Oct 27, 2006 03:19 PM
HatchSpeeD
Jul 17, 2006 03:46 PM
hatchy
Mar 9, 2003 01:57 PM
baonest1
Oct 17, 2002 06:29 PM
