oil and filter
Old May 15, 2004 | 03:26 PM
94civicexlsvtec's Avatar
Default oil and filter
just wondering what kind of filters and oil you guys use.
i used to use castrol 10-30 and pure one filters,then i switched to mobile 1 10-30 with a factory honda filter and went from a 8.3 to a 8.1 1/8th mile. the oil was the only thing changed and i had been runnig 8.3's for over 2 years
just bored and figured i would see what other ppl do
btw: my motor has blown rings in it and doesnt seem smoke any worse with the mobile 1
thanks for the info
Old May 15, 2004 | 03:31 PM
SpeedDreamz.com's Avatar
Default Re: oil and filter (94civicexlsvtec)
I run mobil too. Cant beat the honda filter.
Old May 15, 2004 | 08:32 PM
james111's Avatar
Default Re: oil and filter (30psiCiv)
on gas , most manufactures make a 5w20synthetic oil......
if for race only some manufactures make a zero weight synthetic oil....
the oil filter is a factor depending on if its a race or daily driven car.....if race only wix makes a very low restriction fliter , not reccomended for anything but trace use.....
the back of the box of the filter gives its micron filtration rate.....the lower the number the less restrictive the filter is, but with race only oils and filters the change rate grealty increases.....MOST crew chiefs change the oil and filter between rounds....
i have been in the oil change buisness for 15 years , any question u have i may be able to help...................
regards
james
Old May 15, 2004 | 08:51 PM
turbociv's Avatar
what about anti-drainback valves to prevent dry start up? Can I get a low micron filter with a anti drainback valve?
Old May 16, 2004 | 07:38 AM
Default Re: oil and filter (james111)
i think with the blowby that im having now a zero weight would be a bad idea but on the motor im building now i will try it and the wix filter. i normally change oil after every race night which is around 10 miles ont the oil (10 runs).
but thanks for the info
Old May 16, 2004 | 09:18 AM
quikB18B's Avatar
I run Modil1 10w30 with Bosch Oil filters, I stopped running Oem honda when they swtiched to Fram
Bosch is made by filtech who used to make the honda ones.
Old May 16, 2004 | 10:36 AM
vaporboy12's Avatar
i was runnign 10w30 now that its getting hot i went to some 20w50
mvang001
Aug 21, 2011 06:35 PM
93 del slo
Dec 19, 2008 03:16 PM
Elfstone
Sep 20, 2004 04:12 AM
TsunamiZC
Aug 23, 2002 11:34 AM
CTL
16
Jul 15, 2002 03:14 AM
