200 hp SOHC on 15g?
Old May 13, 2004 | 10:51 PM
Blazin Civic's Avatar
Default 200 hp SOHC on 15g?
I'm gunning for 200whp on a 15g greddy turbo on a stock block. Do you guys think it is possible. Here is the setup list. D15B sohc vtec with factory LSD tranny, greddy 92-95 turbo kit, greddy intercooler, rc 550cc injectors, walbro 255lph fuel pump, test pipe, thermal R&D classic cat back. The engine will be tuned using hondata and boost dialed in with a profec b. Do you guys see this engine holding 12psi on this turbo or am I looking at a huge risk even with a good tune? Has anyone hit 200whp on a similar setup?
Old May 13, 2004 | 11:00 PM
Drew Peacock's Avatar
Default Re: 200 hp SOHC on 15g? (Blazin Civic)
You will make your goal easily, don't forget 1 stage coldr plugs. That turbo max's out around 250whp or around 15psi.
Old May 13, 2004 | 11:03 PM
vteg's Avatar
New User
The 13g in the wrx's max out around 220-230 so a 15g can definately make that power.
Old May 13, 2004 | 11:44 PM
Default Re: 200 hp SOHC on 15g? (turbozxi)
Even though the turbo can handle around 250whp at 15psi will the block be able to take that?
Old May 13, 2004 | 11:48 PM
200whp no problem well tuned after that it gets sketchy upto 220whp reasonably reliable, from there on cross your fingers and hope. From what I'm guessing this is your first taste of boost 170whp in a light car is fun.
Old May 14, 2004 | 12:01 AM
ATS*Mark's Avatar
OG triple OG
ive seen this baby *** turbo pull some impressive numbers . youll make 200whp
Old May 14, 2004 | 03:29 AM
yellowturbo's Avatar
a easy 200 whp for sure... I made a lil bit more than 250 whp at 15 psi on AEM EMS
Old May 14, 2004 | 06:59 AM
oscarmayer's Avatar
the biggest issue you'll run into is the d15 rods and crank are crappy. they tend to break easier than the d16. the d16 has larger rods and crank.
Old May 14, 2004 | 08:32 AM
lgcubana's Avatar
Default Re: 200 hp SOHC on 15g? (oscarmayer)
As said, w/proper tuning yes. Depending upon the age of the internals, I would seriously doubt that the rings will make it for too long at that amount of pressure.
Old May 14, 2004 | 08:35 AM
Default Re: 200 hp SOHC on 15g? (lgcubana)
So would you recommend I run 10psi max and just be happy with whatever numbers it gives me for reliability reasons? Even if I did run 12psi though it wouldn't be daily. I want to do 7-8 daily and bring it up for races.
Old May 14, 2004 | 08:39 AM
SOHC_MShue's Avatar
that hp goal should be easy with your setup.
Old May 14, 2004 | 11:11 AM
boostsohfast's Avatar
Default Re: 200 hp SOHC on 15g? (SOHC_MShue)
There was a member on this board that made I think 202whp @ 10 psi on a d15b... I'm not sure if he still visits the site but I know he used to be on turbod16 also... He had a white hatch.
Old May 14, 2004 | 12:42 PM
lgcubana's Avatar
Someone w/more mechanical knowledge will have to answer how to check the integrity of your stock engine. I would guess that a compression test will give you an indication. IMO 7-8 psi for daily driving is very doable w/your fuel setup.
Old May 14, 2004 | 01:44 PM
RyanEJ8's Avatar
Default Re: 200 hp SOHC on 15g? (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">The 13g in the wrx's max out around 220-230 so a 15g can definately make that power.</TD></TR></TABLE>
I didn't know the WRX only uses a 13g.
Old May 14, 2004 | 02:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazin Civic &raquo;</TD></TR><TR><TD CLASS="quote">So would you recommend I run 10psi max and just be happy with whatever numbers it gives me for reliability reasons? Even if I did run 12psi though it wouldn't be daily. I want to do 7-8 daily and bring it up for races. </TD></TR></TABLE> Thats exactly what I do, on my D16a6 its a good plan if it tuned right you will be happy. You'll need a decent clutch.
Old May 14, 2004 | 04:10 PM
Pfieff's Avatar
Check numbers in sig. That was on a 15g kit on a y7 stock block.
Old May 14, 2004 | 07:38 PM
Default Re: (Pfieffdog)
How many PSI is that at?
budlightjunkie
Jun 16, 2010 10:07 PM
ek9child
Aug 2, 2006 03:21 PM
ek9 ferio
Oct 20, 2004 05:49 PM
B-Series Sol
Jul 27, 2002 07:36 PM
B-Series Sol
Jul 25, 2002 05:08 PM
