Intercooler Air Flow
Old May 15, 2004 | 07:12 PM
H.crx-si
Guest
Posts: n/a
Default Intercooler Air Flow
I know the cooler the air a intercooler receives the better it performs but I plan on using a dsm smic which will be pretty much completely behind my front bumper with no direct flow. Is this a big deal? I could probably rig up a little scoop which forces air up to it but would it really be worth it?
Old May 15, 2004 | 07:19 PM
xenocron's Avatar
Default Re: Intercooler Air Flow (H.crx-si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.crx-si &raquo;</TD></TR><TR><TD CLASS="quote">I know the cooler the air a intercooler receives the better it performs </TD></TR></TABLE>
Didn't you just answer your own question? And why do you think most people get FMIC (front mount intercooler)...because it offers a more direct path of fresh air to cool the IC better.
Old May 15, 2004 | 07:30 PM
H.crx-si
Guest
Posts: n/a
Well I know the obvious I'm simply asking if it will be a sufficent setup. I will be running 5-6psi on a d16a6 if I mount the smic and its not getting much flow will I have any problems? I just want to make sure I have a safe reliable setup.
Old May 15, 2004 | 11:31 PM
D@nnY's Avatar
If you have an inter cooler without air flowing over it you might as well not run anything.....
unplug your radiator fan and let the car idle and see how good cooling fins work without air to remove the heat.....6-7 psi wont make that much heat but it will probably run like crap and might even detonate...DSMs suck man..good luck
Old May 16, 2004 | 06:55 AM
H.crx-si
Guest
Posts: n/a
Default Re: (D@nnY)
Some people dont even run intercoolers I know its not a smart setup but they dont so I'm thinking even if I run a intercooler and its getting very little air its not likely to detonate......
Old May 16, 2004 | 07:12 AM
Pengo's Avatar
Default Re: (H.crx-si)
where exactly do you plan to mount it. if you mount it where the stock resonator location used to be, it should be ok. plenty of sohcs have ran sidemounts there with no problems, esp for low boost. i've personally run with one in my fenderwell with my greddy sohc up to 10psi and no problems
Old May 16, 2004 | 07:19 AM
H.crx-si
Guest
Posts: n/a
Yup thats where I'm gonna mount it and I no longer have the plastic protector there so it should get some air flow. I might just fabricate a scoop for the hell of it behind my bumper grill leading to the IC.
Old May 16, 2004 | 07:23 AM
MrBui's Avatar
hook up a fan to ur ic and you'll be good to go
Libertariat
Apr 3, 2007 08:05 PM
jkeno112
Sep 18, 2005 10:16 AM
servion
Jul 21, 2003 02:30 PM
TurbothisLS
Jun 14, 2002 02:02 PM
