does open dump make inacurate air/fuel readings on dyno???
Old 05-16-2004, 07:45 AM
boosted_dc2's Avatar
Default does open dump make inacurate air/fuel readings on dyno???
my friend just spent some money on a new DP cause the tuner said that when you dont dump back into the exhaus, that the wideband is not reading all the exhaust so the reading is inacurate. is this true???
Landon
Old 05-16-2004, 08:32 AM
IN VTEC's Avatar
Default Re: does open dump make inacurate air/fuel readings on dyno??? (boosted_dc2)
The oxygen sensor only samples a small portion of the exhaust gas regardless of the plumbing.
If it had to sample all of the exhaust, it would be a possible restriction...kind of like a MAF with a flap door.
Old 05-16-2004, 08:50 AM
Default Re: does open dump make inacurate air/fuel readings on dyno??? (IN VTEC)
yea thats what i thought, plus the fact that the dump tube really doesnt let a whole lot of gas out compared to the exhaust.
Landon
Old 05-16-2004, 09:59 AM
Seraph0's Avatar
Yup. O2 only measures a concentration. Doesn't have to be exposed to all the exhaust gas.
Old 05-16-2004, 10:03 AM
1316130057's Avatar
Your tuner sounds correct. In Vtec is correct in stating that the O2 only samples a small portion of exhaust output, but also consider that the exhaust has rolled over it self so many times that the leftover fuel has evenly distrobuted with the contaminated air, so the reading is more uniform. Depending on how close the dump tube is to the runners, you may only be sampling a charge thats closest to the richest or leanest cyl and the overall mixture hasn't blended and has become uniform as yet.
414bb4
02-20-2011 12:32 PM
egb18c5
Engine Management and Tuning
12-31-2010 06:20 PM
lude98SH
10-06-2005 05:38 PM
JunIntegra
12-24-2003 12:11 PM
CKDC2
04-30-2002 01:44 AM
Quick Reply: does open dump make inacurate air/fuel readings on dyno???
