Nitrous Jets Question
Old May 17, 2004 | 06:06 PM
Soccerking3000's Avatar
Default Nitrous Jets Question
i am looking on the Zex site and other places and they give the dimentions of the brass jets but i want to know the shot size like 35, 45, 55, et cetera. I dont know what the .xx equates too in shots could someone post up a chart or soemthing thanks
Old May 17, 2004 | 06:38 PM
Default Re: Nitrous Jets Question (Soccerking3000)
anyone?
Old May 17, 2004 | 07:16 PM
no one?
Old May 17, 2004 | 07:23 PM
Kataku2K3's Avatar
Atleast for the dry systems here are their ratings. http://www.zex.com/Technical/I...Specs/
Old May 18, 2004 | 07:28 PM
Default Re: Nitrous Jets Question (Kataku2K3)
do you think it would be equivalent if i used a fuel jet in the nitrous port? cause i have numbers 34 and that is for fuel could i use that and get like a 60 shot about?
Old May 18, 2004 | 07:36 PM
Kataku2K3's Avatar
Yea, there's nothing wrong in doing so, the jet is just 0.001" smaller. I don't know where you would be hp wise but it's not that big of a deal. How come you don't want to just run the 65hp combination?
Old May 18, 2004 | 07:39 PM
well i am currentlky running a 75 shot and i just want something a little less for those unecpected moments w/o running through as much nitrous, also are all brands the same in terms of shot like if i got an nx nozzle that says 36 on it and then i got a zex nozzle that says 36 would they be the same, other than the fact that nx measures their shots at the wheels? but with other brands as well
Old May 18, 2004 | 07:41 PM
well i bought this kit and it came with teh 75 shot in it and it also came with a few other jets, i've had the kit but i just feel like changing them out i have a
NX: 36, 46, 52
ZEX: 28, 34,
Old May 18, 2004 | 07:59 PM
Kataku2K3's Avatar
I don't work with nitrous a lot and I've really only worked with NOS and Zex systems. If the actual jets are interchangable (i.e. the NX jet fits in the Zex line) then you'll be just fine. I've never tried this so I'm not really sure as Zex jets differ from NOS ones. Sizing wise like I said if you have a 36 jet it's 0.036" so the same amount of nitrous/fuel will flow whatever brand it may be. Just play around, with a dry system increasing your fuel jet or decreasing your nitrous jet will lower your hp and that's just playing it safe. Don't mess around with vise versa unless you're monitoring your A:F, etc. Just my $0.02, sorry I can't help ya more.
Old May 18, 2004 | 08:03 PM
thanks a bunch
Old May 19, 2004 | 03:52 AM
BoredNStroked's Avatar
If your "75 shot" is a .038 jet you are probably getting around a 40 hp gain to the wheels. Assuming your a/f ratio is okay....why would you want to shoot a smaller shot then that? I ran a .044 jet in my dry setup and it added about 60 hp to the wheels just enough to run 11s
Old May 19, 2004 | 06:56 AM
Kataku2K3's Avatar
Default Re: Nitrous Jets Question (BoredNStroked)
Hey Spencer. Soccerking3000, this is the guy you want to talk to when it comes to nitrous
Type-R eg6
22
Jun 8, 2010 06:38 PM
Jeter2NYC
Jul 6, 2005 05:33 PM
ajshades
Jan 17, 2003 03:10 PM
integranator
Dec 22, 2002 02:58 PM
EFing8
Dec 19, 2002 07:59 PM
