is there such a thing as 1000cc saturated injectors ? or am i stuck to get peak and hold?
need 1000cc injectors , is 750cc the cap for saturated?
Re: (greenmonster)
i *think* that some of the subaru guys use http://www.powerenterpriseusa.net hi-z 850cc injectors... that's still not your 1000cc limit, but maybe they have something newer? they are located in irvine.
i don't know what the packaging constraints are, they don't list these as being available as drop-in injectors for hondas.
Re: (greenmonster)
and here are the calcs and info for adding ballast resistors: http://members.shaw.ca/megasqu...esist
Re: (greenmonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenmonster »</TD></TR><TR><TD CLASS="quote">ack thanks guys...you guys have a wiring diagram for a resistor box...</TD></TR></TABLE>
Just wire it into your injector wire.
I power wire and 4 injector wires.
Your stock injectors just dump voltage to ground to open them, so it's real eay to install. wire it up.
b16bri
09-05-2010 02:53 PM
boost_is_best
02-28-2006 03:45 PM
