Anyone running bigger cams with your turbo set up?
Im going from all motor set up with big cams, to a turbo set up, and Im not sure if I should stick with these cams or go back to stock? I read an article recently and they basically said that if you run something like bigger cams, then it will have that much more power with a turbo set up. Just curious if anyone has experimented with their setup or decided to run the bigger cams.
Re: Anyone running bigger cams with your turbo set up? (RTW DC2)
has this been covered in depth before or does nobody have any insight?
Basically as long as you can dial out the overlap with your cam gears, you'll be able to run the cams. Depending on the cams it might be a good idea to calculate just how many degrees of adjustment are possible in the event that there could be interference issues. Most people just use gsr or itr cams because they simply work well and don't cause any grief.
