How does my setup sound...
Old May 14, 2004 | 05:34 PM
Smooth-GSR's Avatar
Default How does my setup sound...
I'm putting the following into my b18b Integra. I don't like asking this question, but how does my setup look and what kind of whp numbers and tq am I looking at. I will be dyno'ing it soon, but would like a guestimate first....
T3 turbo from a nissan, 63/60
log style manifold
30x 6.5x 2.5 intercooler
2.5" dp to stock exhuast
1g dsm bov
450cc dsm injectors
255 walbro fuel pump
for fuel mgmt, I switched to obd1 and am going to get it tuned and chipped with someting similar to uberdata.
I would like to run around 7-8psi on the stock engine.
How does this sound? What kind of numbers do you think I'll put down? Anyone else with a similar setup?
Thanks!!!!!!!
Old May 14, 2004 | 07:27 PM
Rod.'s Avatar
Default Re: How does my setup sound... (Smooth-GSR)
8psi on my ls with a t3/t04e i put down 215. That was with injectors,safc, and walbro pump.
I think you are going to put down probably less than that...you said 2.5" dp to stock exhaust. That is what going to kill you stock exhaust. Get that changed out before tuning cause it will be a waste
Old May 15, 2004 | 01:29 AM
Charles B.'s Avatar
Default Re: How does my setup sound... (redturbocivic)
yea everything looks good except for the stock exhaust. if your really set on running that at least run open dp around the block before you connect it so you can at least feel the before and after difference.
Xathine
Aug 18, 2012 06:53 AM
alghafat424
Nov 10, 2004 11:34 AM
Smooth-GSR
Apr 26, 2004 02:52 PM
chidoks
May 23, 2003 04:11 PM
fire7882
Sep 30, 2002 12:16 PM
