boost controller and wastegate spring question
Old May 17, 2004 | 01:50 PM
TurboCoop's Avatar
Default boost controller and wastegate spring question
I am about to get an electronic boost controller, and I have been running a 7psi spring in my Tial 38mm since I put my turbo kit on a few months ago. I dont know what kind of spring I should put in it now, I want to run like 11psi max, because I upgraded the fuel system, and its on a B18B1 with its low *** compression. Does anyone know what kind of spring I should get, or does it matter?
Old May 17, 2004 | 01:53 PM
quickergixxer's Avatar
Default Re: boost controller and wastegate spring question (jdog1277)
since your runing 7psi of just the spring you probably have a seven pound spring 11 should be no problem with that spring once you get your boost controler
Old May 17, 2004 | 02:04 PM
mattbcool's Avatar
you should just be able to swap out the spring on the tial. only 35$ for a new spring
http://www.importparts.com/sho...age=3
Old May 17, 2004 | 04:16 PM
Cramerox's Avatar
Your Boost controller can only turn down boost depending on what size spring you have in the WG. So that means if you have a 11lb spring, you CANT turn it down to 7lbs, you can only turn it down to 11lbs.
So if 7lbs is the lowest you think you will be boosting then you are fine...dont waste money on a new spring.
Old May 19, 2004 | 12:21 PM
TurboCoop's Avatar
Default Re: boost controller and wastegate spring question (Cramerox)
Alright thanks, I didnt know if the boost controller could only turn boost down from the spring size I have or up from it. I get it now, I'll just keep my 7psi spring in there.
Dunc
Oct 3, 2005 06:00 PM
9deuce9rr
Mar 28, 2004 12:32 PM
BioXide02
Dec 22, 2003 11:41 PM
threatcon13
Feb 2, 2002 11:55 AM
Turbo_Teg
Jan 14, 2002 07:35 PM
