Golden Eagle Mfg oil feed adapter plate...
any one use this? any problems? suggestions?
Golden Eagle Mfg. Vtec Conversion Kit $85 shipped
I will be running a greddy civic 92-95 turbo kit, and i would like to use this to feed oil to the turbo, and run a oil pressure sensor on the Golden Eagle piece.
Re: (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot »</TD></TR><TR><TD CLASS="quote">How many sensors are you able to tap off it?</TD></TR></TABLE>
I believe 2
I believe 2
Re: Golden Eagle Mfg oil feed adapter plate... (integra-modder)
So this will fit in D series blocks? i believe the oil filter size is the same on D and B series but i want to be sure.
H-T White Ops
I just picked up one of these things from tunertoys.com
Can't wait to get the rest of my turbo stuff in so I can finally cross over to the dark side. Muahahahaha.
Re: (igo4bmx)
We have these available:
http://www.importparts.com/sho...=1641
http://www.importparts.com/sho...=2536
Re: (ben@importparts.com)
I must have had the defect of the group, when we installed mine with the new honda oil filter, the threads didn't continue enough on the adaptor for the oil filter to get snug, therefore we started up the car and 1 qt of my new mobil 1 sync came out onto the floor. Got out the grinder, so that it could tighten down more and it works perfectly. I know when i bought mine, no one had problems, but I had to get a little custom on mine to get it to work, maybe it was that one honda filter as well. either way, with the new filter i put on and the custom grinding, works perfectly. I have my oil pressure and oil temp located off it.
Re: (fake mugen power)
I am not going to say they are bad becouse alot of people have had good luck with them but for me it hasnt been the best investment. I have ghad a leak since day one and I just change my oil today and it is worse. Maybe I got a bad one or maybe I didnt install it right but its pretty straight forward. I have had it on and off a couple time and I am really concidering the AC one.
Re: (tSuperbike69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tSuperbike69 »</TD></TR><TR><TD CLASS="quote">I am not going to say they are bad becouse alot of people have had good luck with them but for me it hasnt been the best investment. I have ghad a leak since day one and I just change my oil today and it is worse. Maybe I got a bad one or maybe I didnt install it right but its pretty straight forward. I have had it on and off a couple time and I am really concidering the AC one.</TD></TR></TABLE>
Sounds like you put it ON backwards .... I've seen it happen.
Re: (Honda4CX-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda4CX-T »</TD></TR><TR><TD CLASS="quote">
Sounds like you put it ON backwards .... I've seen it happen. </TD></TR></TABLE>
I am pretty sure I have it on right the side with the seal goes toward the block. I am going to take it back off and try to gring down the stud and see if that takes care of it. I will admit it looks great
Re: Golden Eagle Mfg oil feed adapter plate... (fake mugen power)
i jus got one a couple days ago and its been leakin since...i pulled it off and put it on bout 6 times so far and i gotta try again tomorrow...
Re: Golden Eagle Mfg oil feed adapter plate... (TurboxDC2)
the ac ones dont work with an oil cooler i beileve. i have a GE one that is made for use with an oil cooler, it works great, the only thing i dont like is it only has 2 ports .
Landon
Landon
Re: Golden Eagle Mfg oil feed adapter plate... (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote"> i have a GE one that is made for use with an oil cooler, it works great, the only thing i dont like is it only has 2 ports </TD></TR></TABLE>
That's beacause it was NOT desinged for any other purpose, only VTEC changeovers & turbo oil tap/supply line ....
