how mcuh boost will a G1 Profec-b hold safley?
how much boost with the Greddy profec B first gen hold safley and controlling? I'm trying to see if ti will work for my needs. I have one now but not sure if it is capable of handling 27 lbs os boost or not.
Re: (oscarmayer)
spoke to greddy. Here is what they said.
The first gen profec-b only will do 100+20% over wastegated settings. they said if iw as going to use it, i needed to get a 1.2-1.4 bar spring and then it would run 27lbs ok. The spec2 will do 0-open wastegate setting.
Re: (turbotypeR)
they said it was not prssure sensetative, it was basically only capable of handeling about 20-25% more than the wastegaste was set to. so if you install a 1.2-1.4bar spring, you can then go to 28-30psi if you wanted.
br1ev8
04-06-2006 02:44 PM
Black R
03-26-2005 04:32 PM
