help with turbo timer?
Old May 16, 2004 | 01:46 AM
MattGSR's Avatar
Default help with turbo timer?
I have turbo timer (blitz, old model) installed in my other car but i accidentally pulled one of the wires (purple) when i was changing the carpet. All the functions work except for the timer itself, when i shut off the car it won't keep running. I didn't install this so i don't know how or where this wire goes. Can anybody help, thanks in advance.
Old May 16, 2004 | 01:57 AM
GSRrR's Avatar
Default Re: help with turbo timer? (MattGSR)
looks like that? it says its for the e-brake.
found here:
http://vwroadtrip.peterbeers.n...l.htm
HTH
Old May 16, 2004 | 02:00 AM
NOSED_CRX_VTEC's Avatar
Where did the wire go to?
It could be the e-brake switch wire that stops you car being driven away.
Old May 16, 2004 | 06:54 AM
Rod.'s Avatar
Default Re: help with turbo timer? (NOSED_CRX_VTEC)
If I remember correctly on my Blitz turbo timer. THe purple wire can be a ground or run it to your parking brake. So when you let your parking brake go the timer will cut off
Old May 16, 2004 | 07:15 AM
Pengo's Avatar
Default Re: help with turbo timer? (redturbocivic)
if it's the e-brake safety feature, just find a solid ground you can hold the wire to and see if the timer keeps the car running, that way you don't have to take apart anything yet to get to the e-brake switch
Old May 16, 2004 | 11:01 PM
MattGSR's Avatar
Default Re: help with turbo timer? (Pengo)
im gonna try to see if its ground... i pulled the shift/e brake console when i changed the carpet so that might be it too. thanks guys
Old May 17, 2004 | 08:16 AM
FuriousGeorge's Avatar
my hks timer didnt count down at all when I first put it in b/c I didnt splice the e-brake wire correctly. It is only a matter of 4 screws to take the plastic offaround the ebrake, you can just open it up and splice the wire in and you should be good to go. This is all assuming that the purple wire is supposed to go to the ebrake. That should be your fist order of business.
Old May 26, 2004 | 08:03 PM
Dyno Queen's Avatar
Default Re: help with turbo timer? (FuriousGeorge)
i have the new greddy turbo timer and im having the same problem...not sure where the purple wire goes. I know it goes to the ecu, but to which wire im clueless....and what makes the problem even tougher is that i dont have the p72 anymore, sold it and now have a standalone so i just need to know which clip and which wire i would tap the purple one into, i think its something like speedometer mode or some ****, any help would be appreciated, the brown went to the e-brake so helpppppppp......95 integra gsr is the car
Old May 26, 2004 | 08:14 PM
95turbocivicEX's Avatar
Default Re: help with turbo timer? (Dyno Queen)
DYNO_QUEEN,
The purple wire goes to the speed signal wire on the ECU. You will have to check a manual. My boys 95civic just got a new greddy timer & that is what is says the purple goes too.
-Justin
Old May 26, 2004 | 08:20 PM
Dyno Queen's Avatar
Default Re: help with turbo timer? (95turbocivicEX)
will do, thanks man
NYCFINESTEG
10
May 15, 2005 02:07 PM
ProjectLudeSiR
Dec 4, 2003 07:07 AM
japspec
Oct 26, 2003 01:14 AM
B18EG6
Aug 17, 2002 03:53 PM
