did 2 wire iacv conversion and still problems
Old May 16, 2004 | 02:34 PM
scttydb411's Avatar
Default did 2 wire iacv conversion and still problems
help me!! i'm running obd2b-obd1 harness on my '00 y7 that has a y8 intake manifold swap with td04L turbo. did the 2 wire iacv change using the info from ffsquad. double checked it and i still get code 14-iacv and my idle is jumpy. i've double checked the polarity is correct, but should i get any specific voltage across the terminals? when i checked it, it was in milivolts. i'm assuming this is a resistance type connection like the iat and probably doesn't have a very high voltage. in terms of the coolant lines i connected the one from the back of the block below the intake manifold to the port on the driver's side of the iacv and the line from the passenger side of the block where the intake mounts to the block to the passenger side port on the iacv.
i still have my y7 throttle body on with the iacv disconnected and the ports capped rendering the y7 iacv dead. i want to keep the y7 throttle body on so when i have to go for emmisions all i have to do is swap ecu, reconnect the y7 iacv, and step back to stock injectors to pass.
is keeping the y7 throttlebody on causing my problems? where do i go from here to troubleshoot my problem and fix it? this is driving me nuts! i want to run uberdata and tune so bad.
Old May 16, 2004 | 03:08 PM
scttydb411's Avatar
i hope i just figured it out...i never moved pin b6 to b23. i figured that the obd2b-obd1 harness would handle that, but maybe not. going to try and repin and see if that works.
anyone done this conversion and know for sure if that's what i have to do even with the conversion harness?
Old May 16, 2004 | 04:46 PM
scttydb411's Avatar
just moved pin b6 to b23 and cured the cel for iacv, but now the car idles as if i have a vac leak. i unplugged the y8 iacv and the car stopped idling with that 2k swing of a vac leak and the cel came on and the idle just bounced btw 1k and 1.5k.
i can't help but think that the y7 throttle body must go.
Old May 16, 2004 | 05:54 PM
scttydb411's Avatar
i just got done installing the y8 tb (luckily the y8 gasket was still on the tb and the y7 gasket stayed in 1 piece on the manifold, i just slapped it on) and left the coolant ports w/o coolant on it and it seems to run ok. slight raising/lowering of idle, but after driving it around it seemed to be ok. idle would get pretty low from the rich basemap i'm running. i think i got it. i'm going to tinker with the basemap i've got and see if i can lean it out a little and see what she does.
matt45
Apr 11, 2009 11:52 AM
triple5soul4165
Feb 20, 2009 03:20 PM
combz
Jul 15, 2007 02:59 PM
phasewest
Dec 12, 2004 08:57 PM
scttydb411
May 16, 2004 09:23 PM
