Ls/vtec Turbo
Old May 14, 2004 | 04:19 PM
skwert_720's Avatar
Default Ls/vtec Turbo
What size turbo are you running on your Ls/vtec's? I am building my own currently and need a new turbo. Last race season i pulled some low 13's in the 1/4 mile with an LS turbo (tdo4 13G?) whatever turbo comes with the SOHC Greddy kit. I don't want something that spolls super quick, but has to make decent power. And I also plan on putting it onto a B20/Vtec later on. Any help or suggestions would be great. Thanks everyone.
Old May 14, 2004 | 04:21 PM
1316130057's Avatar
Default Re: Ls/vtec Turbo (skwert_720)
Search. This has been covered numerous times.
Welcome to the board BTW.
Old May 14, 2004 | 04:40 PM
skwert_720's Avatar
Default Re: Ls/vtec Turbo (1316130057)
Thanks for the help?
Old May 14, 2004 | 04:43 PM
1.8turbolsvtec's Avatar
on the left is a t3t4e and my new turbo on the right sc61
Old May 14, 2004 | 06:52 PM
B17aTrbo's Avatar
New User
Default Re: Ls/vtec Turbo (1.8turbolsvtec)
Is that the S cover?
Old May 14, 2004 | 06:56 PM
Tad's Avatar
Tad
they both look like pretty big turbos!
new one definetely beefier though.
Old May 14, 2004 | 07:20 PM
Rod.'s Avatar
Default Re: (Tad)
Why you going to go from ls/vtec to b20/vtec. Just bore your ls block out. Go with a Sc series, anyone would do the job.
Old May 14, 2004 | 07:37 PM
calib17a's Avatar
Just use a b18, b20 cylinders are too weak, do a search on b20.
Old May 15, 2004 | 09:44 AM
Default Re: Ls/vtec Turbo (calib17a)
just to let you know i would not do a b20vtec with out resleving i had a friend that blue 3 motore when he hit 14psi
Old May 15, 2004 | 02:42 PM
1316130057's Avatar
That's all in the tuning. You can run 20psi on stock sleeves and make over 450whp. And that's been proven countless times.
Old May 15, 2004 | 03:01 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1316130057 &raquo;</TD></TR><TR><TD CLASS="quote">That's all in the tuning. You can run 20psi on stock sleeves and make over 450whp. And that's been proven countless times.</TD></TR></TABLE>
Not on thin as hell B20 sleeves it hasn't.
Old May 15, 2004 | 04:38 PM
slowazzhatch's Avatar
Default Re: Ls/vtec Turbo (boosted92)
waa..waa...b20 sleeves are not "thin as hell", they are not that much different in size from a b16a block or b18 block...3mm...if you go by bore size, if you actually measure it, which i will do tonight i have a b20 block/ls block and b16a block all sitting around, i will measure to get the difference
i havent had a problem with my sleeves..and i'm going on 12k miles
edit: get you <FONT COLOR="red">sc61</FONT> and you will be happy
bigplayj17
Jul 8, 2007 09:02 PM
lscoupe
Mar 13, 2005 07:56 AM
my ride
Apr 21, 2004 01:28 PM
743motorsports
Oct 6, 2002 09:24 AM
ITRfaithful
Jun 6, 2002 04:10 PM
