hondata or not
Old May 17, 2004 | 06:12 AM
viney's Avatar
Default hondata or not
iam gettin my ek4 turboed, gettin sleeves ,pistons etc should i just get it mapped wi greddy e or spend 1500 pound thats bout 2300 dollars on the hondata. i stay in the uk and thats how much it would cost over ere.
only got a excedy sports clutch should handle bout 300BHP if i go for the greddywhich i already purchased coz the hondata was just to expensive(but thinkin bout another loan to get the hondata)
so if i go for the hondata i would probably run more than 300bhp but then the clutch wont handle it so wat should i do
another thing if i make 1st and 2nd gear run lower boost and then run more in 3rd,4th and 5th will that put alot less stress on the clutch.
Old May 17, 2004 | 06:13 AM
SOHC_MShue's Avatar
Default Re: hondata or not (viney)
$2300.....um no
Uberdata is your friend
Old May 17, 2004 | 06:17 AM
viney's Avatar
Default Re: hondata or not (SOHC_MShue)
i stay in uk so dont think i can get anyone to set that management up
Old May 17, 2004 | 07:16 AM
SOHC_MShue's Avatar
why couldn't you? You get the program online and then you just socket your ecu and burn the chips with a burner.
Old May 17, 2004 | 07:17 AM
SOHC_MShue's Avatar
Uberdata Forum read up on it here.
Old May 17, 2004 | 07:41 AM
LAKER HATER's Avatar
hondata! do it right.
Old May 17, 2004 | 08:01 AM
Rod.'s Avatar
Default Re: (affiliated)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by affiliated &raquo;</TD></TR><TR><TD CLASS="quote">hondata! do it right.</TD></TR></TABLE>
Old May 17, 2004 | 08:03 AM
SOHC_MShue's Avatar
whats so superior about hondata? I mean yea its better if you actually have the $ to spend on it. If you are a diy kind of guy and don't mind learning stuff then i would rather spend the $30 to chip my ecu and run uberdata.
Old May 17, 2004 | 08:13 AM
Turboteggy's Avatar
2300 for HONDATA?!?!?!?!?!?!?!?!??!?!
Someone is tearing you a new one. Order it ONLINE from somewhere in the states, and have it shipped to you. You can get a fully sleeved and built block from Earl for around 3000..........
2300..........sheesh.
Old May 18, 2004 | 04:01 AM
viney's Avatar
its that much cos i need to travel miles for it and need to stay over nite and stuff and gettin it set up the actual unit ant that much but found someone that might beable to do it at a reasonable prices, ill look into that uberdata tho, thanks for the help
Old May 18, 2004 | 04:52 AM
beerbongskickass's Avatar
That would be an ignorant comment... Ignorant = Lacking education or knowledge.
You need to travel for miles and stay overnight? You would also have to get a loan so you can get hondata? Seriously man, uberdata sounds like it's perfect for you.
Old May 18, 2004 | 04:59 AM
rioninja's Avatar
****, send me $2300, and ill fly over with my wideband and set up uberdata for you
May 13, 2009 06:57 PM
43MA
Jan 25, 2005 10:09 PM
speedyonez
Oct 20, 2003 06:49 PM
93B17A
Dec 10, 2001 07:46 AM
