what diameter exhaust for turbo LS @ 7lbs?
alright guys i have an LS in my civic and currently have 2.25" catback. would this diameter still be sufficient if i were to run a T3 turbo at 7lbs? yes/no will suffice. thanks
Banned
Re: what diameter exhaust for turbo LS @ 7lbs? (HuskerHybrid)
bigger is better in every turbo case.
yes it will work............. but it would work better with larger piping like 3in
As has been said, it would be "sufficient" however you would be losing some power vs. say a 2.5" If you're going to be slowly stocking up parts for a turbo setup, you should sell the 2.25" and buy a 2.5" because you can probably do it and break even on price. Completing a setup is all about the little gains here and there.
Re: what diameter exhaust for turbo LS @ 7lbs? (SleepyEG)
i would highly recommend a 2.5 inch set up if not a lil larger depending on if your gonna upgrade down the road any questions send me an e mail
hatchinprogress
01-09-2006 11:32 AM
Serdar
11-18-2003 06:26 AM
