South florida performance (SFP) vs. inline pro
Old May 15, 2004 | 02:24 PM
95gsrturbo's Avatar
Default South florida performance (SFP) vs. inline pro
can anyone compare the two for me and let me know thier preference--
Im looking at both of these-- ive heard nothing bad about the inline pro except that i have to shave part of the block to fit the turbo.
and as far as the SFP ive had mixed results... chime in anytime
and if you have any suggestions to something else let me know.
Old May 15, 2004 | 02:32 PM
AlphaKennyWun's Avatar
Default Re: South florida performance (SFP) vs. inline pro (95gsrturbo)
I had to cut the block with my sfp manifold too, to fit a t04e housing. Thats no big deal, i didnt care. The quality and performance on the mani is excellent. It has super thick metal and good welds. I just wish they made or i wish it was more common to find a 3" downpipe a/c compatible to go with the mani. For now I have to get a custom one made.
I have no experience with the inline pro but I dont think you would go wrong with either one. They are probably pretty close in performance and quality. I think the inline pro comes coated? the sfp doesnt look too hot when its not coated. I guess that would be my deciding factor and price too if i was in your shoes.
Modified by Turbo Chris at 6:50 PM 5/15/2004
Old May 15, 2004 | 04:17 PM
drvfast's Avatar
I have the inline pro manifold. I didn't have to notch my block much. I have no experience with sfp but I hear good things about there manifolds also. I would recommend inline pro's manifold.
Old May 15, 2004 | 09:00 PM
95gsrturbo's Avatar
Default Re: South florida performance (drvfast)
yea i also need it to be AC sompatible- i would like to run a 3" dp but ill sacrifice that little power for AC
so are either of thse able to use AC with a 3" DP?
Old May 15, 2004 | 09:17 PM
B18Flip's Avatar
Default Re: South florida performance (95gsrturbo)
I really like the inlinepro, good quality, lifetime waranty, and good fitment (i didn't have to notch the block at all).....project dc2 had made a full 3" downpipe that cleared the a/c compressor , or you can flare it out to 3" after the compressor like i did
Old May 15, 2004 | 09:23 PM
95gsrturbo's Avatar
Default Re: South florida performance (B18Flip)
i saw the 3" he made and i dont agree with that= no offense to him but
ive had enough problems with exhaust leaks on a turbo honda for the rest of my life- i dont like the idea that hes only using 4/5 bolts.
also its a really close fit-- i would rather flare like i said.
but any suggestions like that are appreciated
Old May 15, 2004 | 09:28 PM
B18Flip's Avatar
yeah if you really want to use all 5-bolts just use a 2.5" dp that flares out to 3" after the compressor like this:
Old May 16, 2004 | 07:12 AM
95gsrturbo's Avatar
i guess the turbo is bolted on later huh- i dont see it in the pic---
also you could technically flare the 2.5 out a bit earlier right?
and if thats the case cant you do that with either manifold?
so back to the top- which is better if im willing to flare the DP
Old May 16, 2004 | 07:26 AM
MrBui's Avatar
love fab sidewinder! 3" downpipe!
Old May 16, 2004 | 07:31 AM
B18Flip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrturbo &raquo;</TD></TR><TR><TD CLASS="quote">i guess the turbo is bolted on later huh- i dont see it in the pic---
so back to the top- which is better if im willing to flare the DP</TD></TR></TABLE>
the turbine is bolted up in the pic, just picture it w/ the compressor on the other side LOL. yeah you can technically flare a dp w/ either application
Old May 16, 2004 | 08:01 AM
KornyCivic's Avatar
I run an SFP manifold and have had no troubles with it. The shop I get my hondata tuning done by recomends them 100%, they pretty much won't order anything else... I did have to trim my block a little bit, but I think that's pretty standard for any turbo setup on a honda...
Old May 16, 2004 | 10:48 AM
TURBO4drTypeR's Avatar
The manifold is not the problem, Its how big of a turbo you want to fit or use. The bigger the more notching.
Old May 16, 2004 | 10:51 AM
DD_JonnyLee's Avatar
Default Re: (TURBO4drTypeR)
i didnt have to shave at all on my old inline pro with a 5bolt sc61
-jonny
Old May 16, 2004 | 11:19 AM
swlabhot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">yeah if you really want to use all 5-bolts just use a 2.5" dp that flares out to 3" after the compressor like this:
Jeez You're dumping exh gas onto the compressor?! It might not be straight onto it but its still pretty close.
Old May 16, 2004 | 11:37 AM
B18Flip's Avatar
Default Re: South florida performance (swlabhot)
lol i added one of those 1.5" flexible exhaust hoses from napa that dumps it out under the car
almostboostedgsr
Jan 28, 2010 10:50 AM
jojowasha
Sep 23, 2008 12:25 PM
beast59
Feb 21, 2008 07:44 AM
SPOOLINmatt
Jan 20, 2005 08:39 AM
rcsivtec07
Mar 12, 2003 08:03 AM
