white smoke
Old May 13, 2004 | 02:30 PM
kikoman0's Avatar
Default white smoke
i have a turbo'd sohc motor and there's been white smoke coming out the exhaust. No smell of burning coolant...I'm pretty sure I'm burning oil somewhere...smells like burning oil. Compression was fine 175-180-180-185. No oil in front of my block. I'm using 5w-30 Amsoil. My drain line seems pretty okay. What are the signs of my turbo having bad bearings? Anyone know anything about warranties on garett t3's? Thanks for the info.
Old May 13, 2004 | 03:31 PM
Turbo E's Avatar
white smoke = coolant leak into the cylinders. most likely HG. keep an eye on the coolant levels and temps
Old May 13, 2004 | 03:46 PM
Ben Huynh's Avatar
Default Re: white smoke (kikoman0)
Disconnect your turbo piping at the turbo and check for oil.
Old May 24, 2004 | 02:26 PM
kikoman0's Avatar
if i'm checking the turbo piping at the turbo and there is oil does that mean my bearings are bad?
Old May 24, 2004 | 02:27 PM
kikoman0's Avatar
compression is fine and coolant level and temperature is fine. I doubt it's a blown headgasket. I'm definately burning oil, not coolant. I'm unsure if it's becuase of the drain line or the bearings on the turbo.
Old May 24, 2004 | 02:41 PM
VacantBanana's Avatar
burning oil=blue smoke, it wouldnt be white, is the smell sweet=coolant
im also think blown headgasket, any overheating, loss of power?
Old May 24, 2004 | 03:06 PM
buck02's Avatar
im having the same problem i think its the headgasket or the turbo but the turbo is bran new and the motor has alot of miles on it but my coolant isnt bubling out the top of the radiator what degrees is normall operating temp for a turbo car with a full-race mani im running little less than 215degrees its seems little high
Old May 24, 2004 | 03:31 PM
Default Re: white smoke (h22civic2)
in ure case it doesnt seem like, possibly head gasket as well, are u over heating?
Old May 24, 2004 | 03:46 PM
Ben Huynh's Avatar
Default Re: (kikoman0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kikoman0 &raquo;</TD></TR><TR><TD CLASS="quote">if i'm checking the turbo piping at the turbo and there is oil does that mean my bearings are bad?</TD></TR></TABLE>
Means the seals are blown.
Old May 24, 2004 | 06:27 PM
buck02's Avatar
Default Re: white smoke (VacantBanana)
so guys u think my head gasket is blown or the valvestem seals are bad please help
Old May 24, 2004 | 10:22 PM
kikoman0's Avatar
no overheating and coolant level is fine. I'm pretty confident its not the headgasket. Anyone know where I can get a stainless steel braided return line fabricated?
oranginal
Apr 28, 2012 05:35 PM
Joeski99Si
Aug 2, 2009 11:25 AM
lookout22
May 17, 2009 07:37 PM
GReddy_Civic
Aug 11, 2008 11:42 AM
torqueless
Oct 29, 2005 02:59 PM
