Charge pipes? Clamps what is everyone using
I know I'm using regular hose clamps and I boosted 18psi and blew the carge pipe clean off the turbo. I know they make alot better clamps but I don't know what to go with.
Re: Charge pipes? Clamps what is everyone using (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">T-bolt clamps are what you want to use.</TD></TR></TABLE>
I agree, I just upgraded to t bolts on mine, got them on ebay for about $40, or so for 12 clamps Vecco performance.
Re: Charge pipes? Clamps what is everyone using (Boondock Saint)
Get T-clamp the first time and it'll be the last time you will worry about clamp. I went with the worm clamp first running 8 psi and it was *okay* then but once i went to 11 psi, it went nut. everytime i boost end up with a pipe popping out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint »</TD></TR><TR><TD CLASS="quote">
I agree, I just upgraded to t bolts on mine, got them on ebay for about $40, or so for 12 clamps Vecco performance.</TD></TR></TABLE>
stan can actually do it cheaper then that..
check him out.
check him out.
Re: Charge pipes? Clamps what is everyone using (jason190)
Are your charge pipes beaded?
I have used beaded pipes and normal worm clamps with alot of pressure. No problems. Of course T-bolt clamps are a better choice but worm clamps can work well under a budget (or what you had at the time) situation.
I usually use constant tension T-bolt clamps on the compressor housing outlet. T-bolt clamp with spring under the adjustment nut.
Re: Charge pipes? Clamps what is everyone using (BROOD)
t-bolt clamp work great. but like stated above if u weld a bead on the end of your pipes worm claps will work. i'm using worm clamps with the bead method and haven't had any problems.
Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">Use Wiggins</TD></TR></TABLE>
thats some $$$$
thats some $$$$
Re: Charge pipes? Clamps what is everyone using (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron »</TD></TR><TR><TD CLASS="quote">http://partssystems.com/shop/p...TBOLT
Breeze T-Bolts </TD></TR></TABLE>
buy it from them, that site got a good price on tbolt clamps
https://honda-tech.com/zerothread?id=1197423 <-- Along the same lines
http://www.maxspeed-motorsports.com/engineacc.html
I really like the dual hinge setup -- they looks like it will hold very well.
Re: Charge pipes? Clamps what is everyone using (B16A Grenade)
what size clamps would be needed for 2.5" pipe?
Im guessing:
Effective Diameter Range: 2.5''-2.81''
or would the bigger ones be better?
Effective Diameter Range: 2.63''-2.94''
Im guessing:
Re: Charge pipes? Clamps what is everyone using (adictionbass)
Re: Charge pipes? Clamps what is everyone using (SHystrdyGSRtdy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1150195</TD></TR></TABLE>
just be patient on their working process with shipping and dont think about it, then it'll be in your mailbox in no time, unless your like me i call and checkup on them everyday lol i have me a full set of t-bolt clamps from them on ym setup from top to bottom good chit!
nuttybumpo
11-02-2006 06:42 PM
