fmu or afc hack
Old Mar 30, 2005 | 09:02 PM
b18c1Monster's Avatar
Default fmu or afc hack
I need some opinions out there. I have a 95 hatch b18c1 with a drag 3 kit. as far as fuel management would i be better off with inline fuel pump,fmu, and rc310s or the afc hack. Please help with suggestions .thanks.
Old Mar 30, 2005 | 09:08 PM
mtber's Avatar
Sell the fmu and the afc hack etc...
Buy injectors big enuff for your setup & use a management system such as hondata, ubberdata etc.
Old Mar 30, 2005 | 09:10 PM
1slowhatchie's Avatar
Default Re: fmu or afc hack (b18c1Monster)
im in the same shoes ure in right now and i did alot of SEARCHING in the archives about fmu's and the afc hack method and came to a conclusion that both of them are not really safe to run,your better off using hondata or uberdata.
Old Mar 30, 2005 | 09:32 PM
PrettyLude's Avatar
fmu-no
afc hack-not to many success stories to hear about
Old Mar 30, 2005 | 09:42 PM
Rod.'s Avatar
Default Re: fmu or afc hack (1slowhatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowhatchie &raquo;</TD></TR><TR><TD CLASS="quote">im in the same shoes ure in right now and i did alot of SEARCHING in the archives about fmu's and the afc hack method and came to a conclusion that both of them are not really safe to run,your better off using hondata or uberdata.</TD></TR></TABLE>
Old Mar 30, 2005 | 09:51 PM
ProjectDarkBlack's Avatar
Default Re: fmu or afc hack (redturbocivic)
put it this way, after having my SAFC-II for less than a year, my car started giving me the check engine light. Turns out the Throttle Angle Sensor was no longer working. I pulled the ECU out after i figured out what was wrong, and saw the the wiring was just as it should have been. As I expected, after pulling the SAFC-II out, the code was gone. Had this happened with a turbo car, it would have definately blown the engine, as it would not have performed any fuel correction (it read 0% throttle). And as for an FMU, its very innacurate, as it is mechanical and only reacts to boost in a linear manner, and gives peak fuel delivery often a long time before it is required. I am selling both of these items if you are dead set on them, i guess im not much of a salesman
Old Mar 31, 2005 | 12:08 AM
Cray91's Avatar
stand alones &gt; Hack &gt; FMU
Get the best that you can afford. Considering that turboedit and Uberdata are free programs, you can afford a stand alone EMS.
Old Mar 31, 2005 | 05:41 AM
Default Re: (Cray91)
I still dont quite understand uberdata yet. And since im located in CT I dont know of any uberdata tuners close by. What will I need to use uberdata
Old Mar 31, 2005 | 06:46 AM
2point2's Avatar
Default Re: (b18c1Monster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1Monster &raquo;</TD></TR><TR><TD CLASS="quote">What will I need to use uberdata</TD></TR></TABLE>
you will need http://www.google.com
http://uberdata.pgmfi.org/
Old Mar 31, 2005 | 08:56 AM
Default Re: (2point2)
so fmu or hack?
Old Mar 31, 2005 | 10:03 AM
Calvinator's Avatar
hack &gt; fmu
ALSO: I have an SMC fuel controller for sale, pm me. 45 shipped. If you need info on it, search up smc on this board.
Old Mar 31, 2005 | 11:20 AM
oxSLEEPERxo's Avatar
Default Re: (xtremeazian)
go with the hack, if hack or fmu is your only choice. Go with uberdata if i was you, there's uberdata tuners near ct or in ct, can't remember
Old Mar 31, 2005 | 11:24 AM
93turbo16's Avatar
There are a few around. most people will give you a basemap so you can drive the car to get tuned.
Old Mar 31, 2005 | 11:52 AM
Jeffescortlx's Avatar
Hey, xtremeazian I searched the FI section for SMC and got:
Error
» No Results Found
Your search for SMC returned no results.
Please try different search criteria or a different data set.
Old Mar 31, 2005 | 05:25 PM
Default Re: (Jeffescortlx)
ttt
Old Mar 31, 2005 | 09:38 PM
dude, just get engine management. You have to really know what you are doing, or you really have to pay to play. If you get more into it in the future you will end up getting it anyways. You are trying to cut one of the worst corners you can
Old Apr 2, 2005 | 01:44 AM
Default Re: (ProjectDarkBlack)
see the thing is i already have both and dont know which one is safer until I am able to afford hondata
Old Apr 2, 2005 | 07:34 AM
Calvinator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeffescortlx &raquo;</TD></TR><TR><TD CLASS="quote">Hey, xtremeazian I searched the FI section for SMC and got:
Error
» No Results Found
Search "smc" in archives. Should come up with 271 results on stuff about the smc.
Also, look at http://userwww.sfsu.edu/~ecg/SMC/smcplus.htm
Old Apr 2, 2005 | 09:52 AM
TuRbO_CrX_7o2's Avatar
i dont know why so many people hate on fmu's.. ive been using it for more than 2 years with no fuel problems...
(b18c, eagle rods, stock comp je pistons, skunk2 manifold, drag kit @ 10psi)
12:1 fmu, nos inline pump, 345cc prelude injectors, vafc, aromotive FPR.. OBD0
279 whp @ 7200 rpm
218 ft lbs @ 6800 rpm
on mustang dyno
Old Apr 2, 2005 | 09:53 AM
DA9-T's Avatar
Do the hack until you realize your car runs like crap. Then spend the EXTRA money to set up with Uberdata/Hondata. In the long run, you'll end up spending more money. Remember, when you are building a turbo car, FUEL MANAGEMENT is not something you want to "skimp" on.
Old Apr 2, 2005 | 09:57 AM
Default Re: (DA9-T)
is nothing you want to skimp on but if your a/f # are good and making good power theres nothing wrong with fmu's
Old Apr 2, 2005 | 10:29 AM
Iceman05's Avatar
ive been running the hack for a year, upgrading to hondata now. just go *****-out and get hondata, you'll appreciate it later.
Old Apr 2, 2005 | 10:36 AM
DA9-T's Avatar
Default Re: (TuRbO_CrX_7o2)
I just dont like the idea of an FMU. Its just like another hack. All it does is adjust fuel instead of actually controlling it. A standalone type system like uberdata or honda can control and adjust your fuel accordingly, not to mention control your timing as well. An FMU is "fine" for anyone under 7 psi. Using one otherwise could prove to be harmful and wasteful since you aren't getting the maximum amount of power from your setup.
Also to clear things up, I am not saying the Hack or FMU will not work; because it will, it just wont help bring your setup into its maximum or be as reliable in the long run.
.02
Old Apr 2, 2005 | 11:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1Monster &raquo;</TD></TR><TR><TD CLASS="quote">see the thing is i already have both and dont know which one is safer until I am able to afford hondata</TD></TR></TABLE>
i would run the fmu w/ the 310's and vfac for now until you have enough money for hondata...
anyone would rather run hondata then (fmu/vafc), but for people on a buget fmu is fine for a basic drag turbo kit....
im planning on running hondata later this year when i convert to obd1. but for now im happy with my set up..
Old Apr 2, 2005 | 11:11 PM
PrettyLude's Avatar
you don't need to run 310 cc with the fmu
