Turbo LS setup...Help...
Old Mar 31, 2005 | 09:59 AM
freeagent32's Avatar
Default Turbo LS setup...Help...
I finish pick up my crank from the machine and I need help on how to keep it in good condition. The block is not currently wrap with anything...LS Block 84.5 resleeve, micro polish crank...
Old Mar 31, 2005 | 10:10 AM
turboteg96's Avatar
Default Re: Turbo LS setup...Help... (freeagent32)
just make sure you oil the journals and everything you can. You want to keep rust from starting, thats your major concern
Old Mar 31, 2005 | 10:15 AM
Default Re: Turbo LS setup...Help... (turboteg96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg96 &raquo;</TD></TR><TR><TD CLASS="quote">just make sure you oil the journals and everything you can. You want to keep rust from starting, thats your major concern </TD></TR></TABLE>
Can I used WD-40???...and what can I wrap it up???
Old Mar 31, 2005 | 10:55 AM
BlueShadow's Avatar
You should get a quart of engine oil, saran wrap and maybe a bag of terry cloths. get some latex gloves and put them on and get a lot of oil on your hands. Now slather it all over the crank. Now thoroughly soak the terry cloths in the oil and wrap it around the crank, then wrap all of it in saran wrap and try to make it as airtight as possible.
The only thing I would be worried about is the terry cloth leaving particles behind on the crank. That might cause trouble later on.
Old Mar 31, 2005 | 10:57 AM
underpressure02's Avatar
i would use marvel mistery oil. That is what I fog our engines out with every year at the end of summer works great.
chu77
Aug 25, 2006 12:04 PM
blu3g
26
Aug 2, 2005 09:22 PM
jmonee112
Jul 7, 2004 09:43 AM
Witty
Jul 28, 2003 12:33 PM
-16V-
Nov 9, 2002 06:19 PM
