momentary switch relay for boost controller? do they exist?
Old Mar 30, 2005 | 06:07 AM
igo4bmx's Avatar
Default momentary switch relay for boost controller? do they exist?
I'm looking for a relay that activates a momentary switch for my greddy profec b spec II
basical neptune offers a low boost/ high boost switch, based on vehicle speed. But in order to use it, it requires that a on/off relay is wired in conjunction with a turboxs or turbosmart dual stage system... (off = low boost, on = high boost)
the greddy profec b uses a momentary switch to signal the change from low to high (and vice versa), but with the way neptune works with the other types of BCs... it would switch back and forth with a normal relay.....
so i'm looking for a relay that would give momentary current when activated....
The only thing I could think of that is similiar is the flash on a camera, when when current passes through it, it momentarily emits current through the bulb
Thanks
Old Mar 30, 2005 | 07:18 AM
Si Shane's Avatar
Default Re: momentary switch relay for boost controller? do they exist? (igo4bmx)
i hvae the spec 1 and i think i'm going to do a manual switch on the steering wheel to do that. You can have as many as 3 bosot .evels if you dont need to run above the wastegate setting in first gear.
I want to turn the boost controller on, then click it to the next boost level. 1,2,3 gears. Currently i'm running uberdata, and i beliege someone is working on a gear finder, so with that it could be possible to use a cheap ebc and get gear dependent boost, offered in 3 flavors: no ebc, low boost, then ihgh boost.
Old Mar 30, 2005 | 07:23 AM
Boltz's Avatar
Default Re: momentary switch relay for boost controller? do they exist? (Si Shane)
Whats wrong the switch greddy sells?
Old Mar 30, 2005 | 07:28 AM
igo4bmx's Avatar
Default Re: momentary switch relay for boost controller? do they exist? (Boltz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boltz &raquo;</TD></TR><TR><TD CLASS="quote">Whats wrong the switch greddy sells?</TD></TR></TABLE>
nothing wrong with it- in fact people have made DIY setups...
fast is its a momentary switch, and the neptune system needs a on/off type switch
Old Mar 30, 2005 | 07:38 AM
Si Shane's Avatar
Read: 'manual switch' hahahaha
veilside_s2k
Northwest (Sales)
Sep 10, 2008 10:55 AM
igo4bmx
Mar 30, 2005 06:50 PM
2ltrsnailpwr
Nov 27, 2003 05:57 AM
speedworks
Aug 14, 2003 09:05 PM
paulzy
Oct 9, 2001 05:36 AM
