4 bolt DP measurements
Old Mar 30, 2005 | 03:46 PM
b18cEF9's Avatar
Default 4 bolt DP measurements
what are the dimentions of 4 bolt downpipe flanges? the distance between each hole for the bolts. any info is much appreciated
Old Mar 31, 2005 | 05:07 PM
b18cEF9's Avatar
Default Re: 4 bolt DP measurements (b18cEF9)
someone knows this cmon peeps
Old Mar 31, 2005 | 06:02 PM
Evanmb44's Avatar
on which turbo? what is the diameter of the housing? there are different diameters, so the bolts will be different lengths.....if you have the same size diameter on the turbine housing as i do, i can go out and measure for you
Old Mar 31, 2005 | 07:23 PM
b18cEF9's Avatar
Default Re: 4 bolt DP measurements (Turboaddict)
the ones on my turbo are 2 3/4 apart from eachother, just need to know which kinda DP flange i need to buy, not sure what kinda turbo it is, has a 4 bolt pattern tho
monster_c
Apr 12, 2012 03:50 AM
hondatuner020
Feb 12, 2010 05:44 AM
1990si
Apr 9, 2007 05:59 AM
TurboEM1
Oct 1, 2006 05:59 PM
goofball123321
Mar 8, 2004 02:41 PM
