RSX come with a Wideband???
Old Apr 1, 2005 | 09:57 AM
See Are X's Avatar
Default RSX come with a Wideband???
it says here on the hondata website
http://www.hondata.com/kmanager.html
that the RSX's come with wideband oxygen sensors...true?
Old Apr 1, 2005 | 11:19 AM
Muckman's Avatar
Moderator in Chief
Default Re: RSX come with a Wideband??? (See Are X)
true.
Old Apr 1, 2005 | 01:15 PM
redzcstandardhatch's Avatar
something different
yet another reason K series are the best.
and expensive.
Old Apr 2, 2005 | 10:44 AM
See Are X's Avatar
Default Re: (redzcstandardhatch)
so could i use the K series O2 with something like Uberdata to tune my obd1 boosted b16?
Old Apr 2, 2005 | 11:06 AM
non-VTEC's Avatar
Default Re: (See Are X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">so could i use the K series O2 with something like Uberdata to tune my obd1 boosted b16?</TD></TR></TABLE>
probably not..........you need a widband o2 sensor controler to make it work.......
Old Apr 2, 2005 | 01:21 PM
sohccrx's Avatar
Default Re: (non-VTEC)
so if your wideband o2 sensor takes a crap on you, you can just take one from an rsx??
Old Apr 7, 2005 | 03:12 PM
See Are X's Avatar
Default Re: (sohccrx)
would it be safe to tune with this OEM wideband O2???
Old Apr 7, 2005 | 04:15 PM
Adriano's Avatar
You need a wide band controller to read the proper a/f ratio. It doesn't work by it self.
Adriano
Old Apr 7, 2005 | 06:46 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">would it be safe to tune with this OEM wideband O2???</TD></TR></TABLE>
i don't see why not if someone makes a controller that will work with it. The innovate unit I use comes with an oem VW wideband.
Old Apr 8, 2005 | 04:54 PM
NJIN BUILDR's Avatar
Default Re: (SOHC_MShue)
The RSX o2 sensor is around $220.The vw on is a fraction of that.
Glenn
Old Apr 8, 2005 | 05:02 PM
igo4bmx's Avatar
i remember someone posting an ebay auction for the honda insight wideband o2 which was cheap as hell....
Bango_Vang01
Jul 11, 2012 05:40 PM
05khbdc5
Jun 20, 2008 06:24 AM
allnaturalb16
Nov 15, 2006 09:45 AM
Terrible One
Jun 8, 2006 12:56 AM
onyx00
Jun 12, 2003 02:40 PM
